I purchased a 2009 206 Signature at the end of last season. Before winterization, the tech told me that all the gauges were dead. Is this the same issue with later models?
This is a sticky topic.
A Signature Edition would not have this issue since those boats don't use a gateway.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
TechBeerOriginally posted by TechBeer View PostIf you get this far in this thread and have 1 or more of your gauges out AND don't want to shell out the big bucks for the bypass kit private message me. I have fixed ~20 or so of these gauges at 100% for a bunch of members. It's not that difficult and seems to be a permanent fix. In my experience if any of the gauges work OR if your LCD on the larger gauges still works then it's likely NOT the gateway, it's the gauges. However.....if you have an earlier boat where the pitot tubes run into the gateway and haven't fixed this problem then it could very well be your gateway.
I have a fuel gauge that I need repaired… I am new and unable to private message you. Can you PM me?
I'm having some issues with my gauges intermittently not working. 2007 SV211 Team Edition. Here's a thread I started with more detail (LINK). I'd like to try TechBeer's fix but am unsure if it will totally resolve my issues as my LCD display on my RPM gauge shows signs of not working properly and will sometimes show partial characters.
Has anyone tried that fix in a similar situation? I'm planning to pull my gateway box this week to inspect for corrosion and clean if necessary.
Lastly, does the Nautique Parts faria gateway replacement kit include depth?
Do you have any information on the under dash wiring with perfect pass for the new kit i feel like i have figured out everything but not completely sure i have the cruise wired up correct thanks
Recently acquired 2003 206 limited. Tach and volt gauge not working.
Looks like Oil pressure gauge was replaced with a nautique brand (but different) gauge. But it functions properly and from the stock sending unit (maybe through the gateway? I'm not sure). Speedo functions as it should, including all aspects of the digital readout.
This leads me to think that the gateway is functioning properly. However, the tach is completely dead including the backlight. Same for volts. If I understand things correctly (after reading 14 pages of this thread), the signal for the volts comes daisy chained from the temp and fuel (and oil?). So if those are working, the issue is the gauge itself, or the last bit of the connection?
Sounds like the tach would go through the gateway.
I guess i'm curious, is there also a 12v power and ground for each gauge that would control the power for the stepper motor and backlight? Thinking perhaps I just have a bad wire (optimistically) vs bad gauges. I could live without volts, but a tach would be nice.
Another question: if I were to install stargazer PP, where does the tack pull from and how is that wired? I've only installed on a GT40 boat, and that was straight forward - tap off the tach wire next to it.
Thanks! This thread is awesome!
Liamfm , are volts reading properly on the LCD? If so, TechBeer can help you with the Volt (and likely the Tach) gauge.
He is also working on a conversion kit that would allow you to get speed from a source other than the pitots which eliminates the risk of flooding the Gateway if the pitot connection develops a leak.Last edited by sgregg; 08-26-2025, 12:20 AM.
Edit: (Starting over) - The LCD on the tach is dead, so I can’t see any information there. I pulled the dash and the tach is the first one in the daisy chain, so it must be getting signal and power since the remainder of the gauges work (except the volts, which is the last in the chain). Thus, I suspect the gauge itself is dead, as is the gauge for the voltmeter. TechBeer if you care to PM me, or here, I’ll gladly take some advice on trying to bring these back to life.Originally posted by sgregg View PostLiamfm , are volts reading properly on the LCD? If so, TechBeer can help you with the Volt (and likely the Tach) gauge.
He is also working on a conversion kit that would allow you to get speed from a source other than the pitots which eliminates the risk of flooding the Gateway if the pitot connection develops a leak.Last edited by Liamfm; 08-26-2025, 06:20 AM.
Hi, I have a 2006 196LE, (Gateway, no pitots) purchased in 2020 with Water Temp and Oil Pressure gauges inop. Tried replacement with used gauges, no change. I was reading the oil pressure and water temp on the Tach MFD LCD using the menu buttons until August 2025 when those reading were gone and replaced with the letters for 'no data' (something like that). Last week the Tach LCD is partial segments of text, basically useless. I read this thread extensively in 2020-2021, it seams that two root causes exist, gauges developing mechanical failures and the CAN data from the Gateway box becoming corrupted. I suspect mine is the CAN data stream.
I researched in 2020 and again this week, 'Livorsi' gauges. They have SAE J1939 gauges that I think will work if I connect the MEFI data directly from the engine and bypass the Gateway box. I'll get a matching non-CAN electric Livorsi gauge for Speedo.Their 'Vantage View' line of CAN Bus Gauges are here: https://livorsi.com/product-category...an-bus-gauges/. Large CAN Tach and 4 small CAN gauges for OIl, Water, Temp & Volts, large Electric non-CAN Speedo, wiring and menu switches are about $1600. I'll have to mount the menu switches somewhere since Livorsi VV series doesn't offer a Speedo or Tach with menu buttons.
It's a lot to spend on a plan that I'm only 90% sure will work. I confirmed my boat's CAN language is SAE J1939 and MEFI version is MEFI-4b using part number on back of the ECU and BillaVista. com Tech Article, which has great MEFI info. I'm curious if anybody has investigated using new CAN gauges like Livorsi, VDO, Veratron. If you've thought about this also, please reach out to me so we can collaborate. Thanks, BruceLast edited by Brucetheshark; 11-23-2025, 04:29 PM.
Why not just do a standard Gateway Bypass that you know will work?
https://www.silvercovemarine.com/res.../gatewaybypassPlease do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Working on my neighbors 06 Ski Nautique Limited and need the fuel and volt gauges repaired . I see that techbeer can rebuild these. Could you please contact me through an email to tngmotorsports@aol.com as I've tried to send a PM through this forum but it appears that as a newbie, I cant.
Jerry
Hi Jeff, regarding 'why not' the Nautique Parts retrofit kit:
The NP Gateway replacement kit has shortcomings, I call it a “downgrade kit’. The hour meter is not tied to J1939, only records hours powered-on. I assume it maintains the MIL light function, but it does not provide clarification (that J1939 provides) of what issue caused the MIL light. My plan is the same price and provides the J1939 data to the Tach LCD, which can be menu toggled to get all engine data, lake temp, air temp, lake depth, DTC's.
The NP kit uses Faria gauges, the company that created this system that we've discussed for ten years and 14 forum pages now. I don’t like to spend good money after bad on a company that caused my situation.
Hopefully not coming off as rude, just giving details for others not far enough down this path to know the history.
Thank you for your work on this forum,
~BruceLast edited by Brucetheshark; 11-30-2025, 02:44 PM.
. lol....I like you already....I don’t like to spend good money after bad on a company that caused my situation.2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
😂 1Comment
I'm working on my neighbors 06 limited with these gauges. I need a fuel and volt gauge repaired, or if anybody has retrofitted to the new setup and would be willing to sell thier old gauges. We're interested in purchasing them. All of our systems are working properly, just need the indicators. Thx
