Repair for Dead Gauges on 2003-2006 Nautiques Caused by Bad Faria Gateway
This is a sticky topic.
  • TechBeer
    • Jul 2014
    • 141
    • Atlanta
    • 2006 SV211, 1986 Ski Nautique 2001
    #211
    Brucetheshark Not sure if you are still looking at this but I can certainly fix your individual gauges that don't work. The gateway is blamed for a lot of issues but 90%+ of issues are a flaw in the individual gauges which is easily repairable. Especially for a gateway without the pitot tubes. PM me if you want to go into more detail.
    I agree that the engine ECU data is likely just a CAN J1932 protocol. However the output of the gateway is a 2 wire proprietary that is not a simple CAN bus. If the data is available on the LCD screen(s) but not on the smaller gauges, the problem is with the gauge, not the gateway. If you get garbled data on the LCD and/or the nav lights don't work and/or the needle doesn't move this is an indication of a bad gauge (fixable).
    If you want to keep the original look of your Nautique I suggest fixing the gauges that go bad.
    • Brucetheshark
      • May 2019
      • 15
      • Watts Bar Lake
      • Spring City, TN, USA
      • 2006 SN 196 Ltd Former 2001 PS190 Former 1995 Supra Ts6m Former 1986 Supra Ts6m
      #212
      My GW Box CAN Msg to the dash is likely corrupt, or the Speedo & Tach LCDs both went bad at the same time. When I started the last ride of the year to pull the boat out this fall, both the LCDs had minimal segments working, and the Speedo went into alarm mode. When I bought the boat in 2020 the Oil & Temp gauges didn't work, and continued to not work when I replaced them.
      Edit: The Speedo/Tach LCD issue above was due to a dying battery, at least that's the initial assessment, not water tested yet. It was past normal old age.
      TechBeer repaired my gauges with capacitor change out over the winter, great guy. Met me at an Interstate exit on my way to FL and back to TN.
      • TechBeer
        • Jul 2014
        • 141
        • Atlanta
        #213
        Interesting. I've never seen a situation where 2 of the small gauges worked and the gateway had an issue. I believe Temp actually come from the engine ECU via the CAN interface. Oil pressure comes from a separate sending unit, at least up to 2005. Not sure on the larger gauges but garbled messages on the LCD is a classic symptom of gauge failure.
        If you have some down time I would be happy to test all 4 gauges in my lab. If they are all functional I would just ship them back to you. PM me if you are interested.
        • teamseal
          • Dec 2006
          • 414
          • Panama city, Florida.
          • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
          #214
          2006 is a one year only application for pcm engines as it is a MEFI/DBW configuration. gateway conversion kits are nothing more than installing a analog set of gauges and a over complicated wire harness. keep in mind all pcm engines generate a analog signal through their ECM's.
          TechBeer: is this a hobby to repair gauges or do you do this as a job? would like more info on what you do repair or can repair? we get a lot of calls at DIM for many of the gauge failures of many manufacturer boats. you can direct email me to support@nautiqueparts.com
          Merry Christmas
          Jody
          • TechBeer
            • Jul 2014
            • 141
            • Atlanta
            #215
            Hi Jody. Sent you an email but I assume it's really support@nautiqueparts.com??
            • brit_hunsicker
              • Oct 2014
              • 483
              • Overbrook, KS
              • 2001 Super Air Nautique
              #216
              Let me preface this with I copied and pasted from what I posted on the Nautique Boat Owners group, so my apologies that it’s explained a little more than this group needs. Does anyone in here have experience with both kits an have a preference? I have my own pros and cons for each kit looking int them, but never dealt with one hands on. This is for a 2006 SV-211.
              Looking for input from people who have done either of the available gateway conversion kits for mid 2000s Nautique’s. Bonus points if you’ve had experience with both kits as your insight would be very valuable. I want to know which product seems to function the best and integrated the most seamlessly. The price difference in kits isn’t enough to sway me one way or another.
              SP-14-1246 - This is the kit NautiqueParts.com offers. It has been around for quite a few years, but had several different changes throughout the years. I know the most recent update was 2022 or 2023 but haven’t read much feedback on it since that update. It appears all gauges match now, they didn’t for a while, let me know if you know otherwise. I like this kit because it appears to keep all factory functions in the allotted factory dash holes. No problem leaving stargazer PP in place and powering it. It does seem to be a bit more complicated to install, but if it gives me a better finished product, that is fine.
              TRD-2001-CC - This is the kit that Ron Tanis developed and sells on skiboatpartsonline.com. A few years ago he switched from Faria gauges to his own gauges and they have connectors to plug and play with factory wiring. This kit easier to install from what I’ve read. The kits appears very nice and is offered in black or white. I’m confident in quality coming out of Ron’s shop with his name on it. However, the downfall to this kit is you lose the depth/temp gauge, in the factory holes anyways. He says an additional gauge can be ordered and pigtail added on his harness to regain those functions, but the gauge they sent me a link to was a generic Sierra gauge that was ugly and only appears to do depth alone. I’m waiting for a response on if they offer a different gauge that does both or if they can adapt the Faria gauge offering that Nautique uses in their kit to do depth and temp. I’m not willing to lose depth or have a janky looking add on gauge, so hoping there is a good option for this.
              Ultimately, I like both kits for their own reasons, so I need some real world feedback. I wanted to go with TRD because I’ve had great luck with Ron and his expertise is invaluable when it comes to all things boats. Maybe I just need to call him on Monday to get for sure answers to my questions.
              • TechBeer
                • Jul 2014
                • 141
                • Atlanta
                #217
                brit_hunsicker - you don't really explain your reasons for doing the bypass but I assume you have 1 or more gauges that have gone bad. The 2006 SV-211 does not have the pitot tubes so water ingress into the gateway will NOT be an issue. In fact I would bet your gateway is just fine. I have fixed over 100 gauges for folks on this blog and would be happy to help you if you PM me. Fixing all 6 of them (if that's what you want) will be way cheaper than any of the bypass strategies. AND you retain the original look of the gauges. There was actually a design flaw in the original Faria gauge design that make them go bad after ~10-15 years. I address that design flaw. BTW I also happen to have a 2006 SV-211.
                But if you are dead set on a bypass kit go for it.
                • SilentSeven
                  • Feb 2014
                  • 2154
                  • Bellevue WA
                  • 2004 Nautique 206
                  #218
                  +1 for TechBeer's fix. He repaired multiple dead gauges in my friend's 2005 Nautique. And I'm in the final stages of installing his 'pitot to paddlewheel' speedo conversion kit. He knows his stuff.
                  Bellevue WA
                  • NZC
                    • Dec 2019
                    • 1
                    • Ankeny, IA
                    • 2006 SV-211 Team Edition
                    #219
                    TechBeer
                    I've read all your posts on this and really appreciate everything you've written up. It was super helpful. I've got a 2006 SV-211 with dead gauges. It was a slow dying process with fuel and voltage followed by oil and temp then speedo and tach at the end. For a while, the digital readout worked on the speedo and tach but now they are all dead. I'm getting various data bursts from the gateway box output on my o-scope so I assume the gateway is good. Would you concur with this assessment? I can rebuild the gauges but wanted to see if you thought it was just stepper motors or should I go ahead and do the capacitors. How likely is it that every gauge is bad? I've tried three of them in the first position and none have worked.
                    • vpickard
                      • Apr 2026
                      • 1
                      • Hillsborough, NC
                      • 2006 Air Nautique TE
                      #220
                      TechBeer Hey, I've been reading up on some of the posts to fix the gauge issues, just wanted to say thank you for taking the time to dig into all of this and share your findings! I've got a problem with 2 of my gauges, wanted to see about getting your repair services. Can you PM me when you get a chance? I'm still "new" to the group, can't PM you just yet (lost/forgot my original login from some time ago...:-( )
                      • jherbolic
                        • Sep 2025
                        • 2
                        • Halifax Nova Scotia
                        • 1994 prostar 190 2004 216 team eddition
                        #221
                        TechBeer Hoping you can help me with my gauges. My tach needle will not work but the screen is still functioning, although it says 0 hours ( like it’s not getting the data from the faria box?) the temp gauge is also not working. Rest of the gauges work fine, pulled the faria box and was perfect inside. 2004 air nautique 216 team edition
                        • functionoverfashion
                          • Jun 2017
                          • 512
                          • New Hampshire
                          • 2003 SANTE
                          #222
                          TechBeer or anyone else interested, I've got a tach and fuel gauge from an 03-05, I believe they both worked when they were removed and replaced with a bypass kit. Happy to pass them on to anyone who wants to pay the shipping.
