Under water lights 2009
  • dizzyj
    • May 2005
    • 73
    #61
    received my lights yesterday as a matter of fact.
    first thing I noticed is how heavy they are. Very solidly built. Did a quick bench test and they are BRIGHT! like, dont look into the light carolayn bright!
    Ill probably install this weekend.
    • kevfran99
      • Sep 2008
      • 335
      • ATL
      • 08 210 SAN Team
      #62
      That would GREAT! I know there is alot of us waiting to hear and see pics of them installed!
      '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
      Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
      -GO DAWGS!-
      • dizzyj
        • May 2005
        • 73
        #63
        one thing is that these will be a permanent install. you have to use a 1/2" drill bit. and drill a 1/4" deep hole to recess the wire. Im sure thats possible to re-gel coat in if you for whatever reason changed your mind, but its not going to just be be 3 screw holes and a tiny hole for the wire. measure 3 times
        Should also mention that the along with the light are detailed instructions, a mounting template, and some tape to mount the template. I thought that was a nice touch.
        • wakemann
          • Oct 2008
          • 7
          #64
          Nice dizzyj take some pics of the steps of your the install. It would be interesting to see how easy it is to install. I'm really interested in this product.
          • wetfoot
            • Jan 2004
            • 90
            • SoCal
            #65
            I just signed up for 2 in blue.
            Yellow_Flash_Colorz:
            • wakemann
              • Oct 2008
              • 7
              #66
              Where did you do that at? PDT_018
              • jchamlin
                • Jun 2004
                • 171
                • Charlotte, NC
                #67
                Are these heat sensitive like the CC ones are supposed to be? dizzyj, are you hooking these up to your stern light or a separate switch? Looking forward to seeing the install pics.
                2000 Air Nautique
                • dizzyj
                  • May 2005
                  • 73
                  #68
                  done
                  finished the install. pretty easy. drill a couple holes, add some silicon, mount, then tap into your curtisy lights. (thats what I hooked them up to)
                  only thing I would do different is that for the mounting screws, I would only drill a pilot hole. The directions tell you to countersink using a bigger bit, then a small bit, but the holes are very close to the edge of the light. You can see one of the counter sink holes peeking out from behind the light in one of the pictures. I dont see a reason for the countersink on these holes.
                  Ill hit that spot up with some gel coat at some time.
                  • Miljack
                    • Dec 2004
                    • 1635
                    • Charlotte, NC
                    • '08 230 TE ZR6
                    #69
                    Dizzy,
                    nice job, I just got some in blue...I was on the fence with red (my boat colors are almost the same as yours), but I like the water color of the blue units.
                    What is your center to center distance on the lights? I asked Ken about it, and he said he's done about 2 feet apart.
                    BTW, do your lights have only 5 led units?
                    Oh yeah, the lights are very well built, they have "stands" where the screws go through so that water can get behind the lights to cool them, I guess. Wiring is completely potted where it comes out the back, nice and heavy stainless housing, good job Bullet!
                    2008 230 TE-ZR6
                    • dizzyj
                      • May 2005
                      • 73
                      #70
                      Thanks! not sure of the distance. I basically put them as far apart as I could while still getting easy access to the wires. I used the lifting hooks as guides.
                      • SurfRC
                        • Jun 2008
                        • 47
                        #71
                        dizzyj, looks great thank you for posting the pictures!
                        • saceone
                          • 650
                          • Montréal
                          #72
                          can you describe the feeling of drilling trough the hull of your boat? must be intense.
                          • dizzyj
                            • May 2005
                            • 73
                            #73
                            lol, im addicted to it. only problem is, this boat already has everything. nothing left to drill holes for.
                            • wetfoot
                              • Jan 2004
                              • 90
                              • SoCal
                              #74
                              Looks great Dizzy!
                              Have you experienced any problems drawing too much power tapping in to the courtesy lights circuit?
                              I was thinking of doing the same, and adding a switch to isolate them if needed while the boat is out of the water.
                              Thanks.
                              btw: They say to countersink any drilled holes to help avoid spider cracks.
                              • kevfran99
                                • Sep 2008
                                • 335
                                • ATL
                                • 08 210 SAN Team
                                #75
                                LOOKS GOOD! any pics in the water????
                                -GO DAWGS!-
