Is correct craft saying the lights go dim or cut off if the LED under water lights are on and the boat is not in the water? ( Internal temperature sensing to automatically adjust light out put when not being cooled by water)
Under water lights 2009
2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro airTags: None
RE: Under water lights 2009
Probably dim...
Does somebody has some good pictures of the LED ligths? In and out of the water?! How are they operated? The same button as the docking lights?230 with ZR6 running on propane
230konrad. As far as I understand they could be added to any model. I want to order them for our 2007, but want to have the possition right at the transom. As far original as possible!230 with ZR6 running on propane
I have them ordered on my incoming 196, once it gets here I will post some pics.
Mounting should be flat against the transom with 1/8" holes drilled through the transom for power, at least that is what they do with MasterCrafts.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
