I am in the process of installing an auto ballast system on my 99 Air direct drive and wanted to let everyone who is considering this project know a few things.
1. Pulling out the hard tanks is a royal pain, especially if you have no helpers. Unless you cut them out (which I opted not to do), moving the gas tank forward is necessary, and getting the necessary supports unbolted is not easy. So if you have a Sport instead without the hard tanks, consider yourself lucky. 3 hours and many bloody knuckles later, I finally succeeded in getting them both out. I did have to cut the vent lines and intake lines, as the hoses simply wood not come off the hose barbs. Oh well.
2. I ordered a 1.5" thru-hull and ball valve as I was going to use a single thru-hull and manifold for 3 ballast puppies. However, I don't think there is sufficient room in the engine box for a thru-hull and ball valve that large. As such, I will likely be switching to 2 x 1" thru-hulls, using 1 for the fore bag(s) and 1 for the stern 2 bags. I think there will be enough room for 2 x 1" setups in the engine box.
3. The V-drive sacks fit almost perfectly in the rear cargo area after the hard tanks are removed. They do not wrap around like the hard tanks, so you lose a little bit on the sides that perhaps a custom sack could get you, but apart from that, it's like the v-drive sacks were made for this space. I wish the top valve openings on the bags were further out toward the edge so that the vent fitting could tuck up underneath the higher point along the gunnels, but that would be too perfect I guess.
