2002 SANTE resto project
  • rbalan
    • 328
    • Georgia
    • 2002 SANTE
    #256
    Originally posted by t.franscioni View Post
    And one more simple but important modification. So everyone complains about the bow of these boats always being damp and smelling of mildew. I added a drain hole at the back end of the bow area. There is already one at the front but the front is usually the highest point so for all the complaints about bow carpet mildew in these older boats, this is why..... add a drain hole.
    Did you think about cutting the wall(s) behind the hole to fit a larger belly sac. I have a 2002 as well and am thinking about getting rid of the belly tank and going with a larger sac. I have a FlyHigh rear seat sac that I can put in its place although it’s about 10” too long. I’ve heard it said that the tank is 300 lbs, but I roughly calculated it closer to 260-270. I think you can get a 50” long sac in there and be close to 400 lbs or so. Getting more weight up front in our boats seems to be the bigger challenge.
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      #257
      I used to know all kinds of stats on the under bow square footage. I was crazy back then, took a few years of therapy now I think I got my life back in order and am not consumed by this boat project….. Just kidding I’m still crazy, I just don’t get anything done. I had a custom under bow bag made for this project, it’s somewhere in the mass of parts I have scattered around…. I wanna say the bag I had made to fit was calculated at like 450 lbs. Most of the increase in weight came from all the unused space in front of the bow hard tank. Whether it actually fills to 450 I don’t know, my guess is you can get about 100 lbs more for sure going from hard tank to bag and filling that entire area with water.
      not sure what the wall is your talking about behind the hard tank. I can’t remember what was there.
      • t.franscioni
        • Jun 2014
        • 715
        • United States
        • 2002 SANTE
        #258
        Originally posted by brit_hunsicker View Post
        It's been nearly a year since I got on here and this project popping into my head is what made me log on. I thought for sure I'd be looking at a picture of the boat on the water...
        I’m still drinking the same beer from the last posted update too…..
        • rbalan
          • 328
          • Georgia
          • 2002 SANTE
          #259
          The wall I was referring to is the divider between the belly tank and the space under the bow.
          • t.franscioni
            • Jun 2014
            • 715
            • United States
            • 2002 SANTE
            #260
            The hull stringers on the right and left of the hard tank? Those are the only walls I can think of not sure if that’s what your talking about but if so then no I wouldn’t cut into those that’s a major structural component of the hull. I’d have to see a picture of the wall your taking about to be sure because I don’t remember any walls (besides the stringers) when I removed my hard tank.
            • rbalan
              • 328
              • Georgia
              • 2002 SANTE
              #261
              It’s the wall behind the hole you are pointing at in this picture. The more I think about it, you would be limited in gains and probably not worth the effort. You would have to cut more out of that area of where your hole is drilled as well.
              • t.franscioni
                • Jun 2014
                • 715
                • United States
                • 2002 SANTE
                #262
                Ahhh ok. That’s not a wall it’s just a step in the floor. It’s all open underneath from front of bow all the way back.
                • Camel_Towboat
                  • May 2020
                  • 14
                  • Southern CA
                  • 2000 Pro Air Nautique
                  #263
                  I just spent I don't even know how long reading all 18 pages of this thread and I only logged in tonight trying to find some gelcoat repairs tips. I'm blown away. And it hits very close to home as I have a 2000 PAN and can see my boat in most of the pictures. Have there been any recent updates?
                  • ScooterMcgavin
                    • 1551
                    • 2014 SAN 210 TE
                    #264
                    Any progress made over the winter T?
                    1989 Sport Nautique
                    • t.franscioni
                      • Jun 2014
                      • 715
                      • United States
                      • 2002 SANTE
                      #265
                      Nothing right now. I just started back up on this project so should have some stuff to share soon.
                      • JimBoat
                        • Aug 2017
                        • 28
                        • Alberta
                        • 2002 SANTE
                        #266
                        This is an amazing restoration and I’ve been following it over the years. Mine is a 2002 SANTE with the same colour scheme. It’s like seeing what mine could be. Hope its still progressing as you are doing a fantastic job.
                        • t.franscioni
                          • Jun 2014
                          • 715
                          • United States
                          • 2002 SANTE
                          #267
                          Getting ready to get back to it… not much has happened over the last couple years as you can tell from the posts.
                          • JDC02SANTE
                            • Jul 2021
                            • 157
                            • Indiana
                            • 2002 SAN 210 TE
                            #268
                            Just quickly skimmed all the way through your project. Awesome! Looking forward to the next stage. Keep it up.
                            I just bought the exact same boat in July of '21. Stereo is my first $$ project that I want to do. So far just a new steering cable, plugs, wires and cap.
                            Oh, and find out why I can't keep my battery from dying all the f'n time.
                            Pic from when I picked it up days before the 4th of July weekend last year....
                            .​...to this 4th with the family.
                            • t.franscioni
                              • Jun 2014
                              • 715
                              • United States
                              • 2002 SANTE
                              #269
                              Nice!!! Twinsies……only difference is yours actually floats on water!
