Seadek vs Diamond Plate on a trailer?
  • Evening Shade
    replied
    Originally posted by wakejunky View Post
    Depending on how the diamond plate is installed. If it's riveted or bolted to the trailer fender, water usually doesn't dry up underneath and will ultimately start to rust at the bolt holes. If it's double faced tape down then I don't think you'd have the same problem. But, I would vote for some foam type material because it offers a non-slip surface.
    The diamond plate is installed with double sided adhesive I believe. At least that's how it was installed on my 2 previous Boatmate trailers.
    Leave a comment:
  • SierraWave
    replied
    Seadek
    Leave a comment:
  • wakejunky
    replied
    Leave a comment:
    replied
    I have always had SeaDek on my G23 trailers, and it has held up pretty well while I have owned them. The light gray did get a little dirty, but I was able to clean it back up. This year I did black SeaDek on the trailer, and it still looks great now after several months of being outside.
    Leave a comment:
  • Evening Shade
    started a topic Seadek vs Diamond Plate on a trailer?
    I'm about to place an order on a new boat and trailer and I wanted to get some opinions on Seadek vs. Diamond plate on the step surfaces of the trailer. The Seadek looks good, but I'm afraid that it will get very dirty and be hard to clean. Not sure how it will hold over the years on a trailer. Should I stick with diamond plate?
