Well, I was finally able to get my winter ballast project (ran WAY into season!) installed and tested in our boat. The boat is a '99 ProAir (direct drive) and the summary of the project is as follows;
Install fill pumps X 3 (Tsunami 1200)
Install drain pumps X 3 (Tsunami 800)
RV gate valve
Fill pump manifold
Plumbing for system
Electrical wiring (about 120 feet)
Ballast switches x 4
Removed stock rear hard tanks
Install new "sub floor" for trunk
custom ski locker sack
2 "semi-custom" trunk sacks
I have some pics, and I have yet to get a photo of the improved wake, but I should get some of those soon.
the subfloor-used 1/2" HPDE with reinforcements in both directions. I used 1"x2" alum. rect. tubing running fore and aft and tied into the bracket used to hold the lifting ring.
The picture of the sack full from the side is just to show approx. volume of the bag. They measure 19" x 19" x 42", they are the "Gravity Games" OEM bags from Supra. I thought they would better fill the space than the standard V drive bags, full they are 565 pound each, I have no idea how full they get in my application, but they look pretty full.
I'll do a better post and write up on the project when time allows.
My first observation is the wake is great! I need to fiddle with speed and how much weight to run front to rear. I also noticed that I probably need a bigger manifold for the fill pumps. The system drains pretty well, and will almost suck the bags flat.
BTW, thanks to everyone that answered my questions, as I basically copied whatever I could, and tried to learn how to make a system like this functional. I probably went overkill on some things, but I didn't want to mess with this once it was installed. So far, so good...
I'll post wake pics soon...
Jack
RV gate valve
Fill pump manifold
Plumbing for system
Jack
