does anyone know were i can get a jabsco water ballast puppy(reversable) pump. im looking for it to plumb a fatsack system.thanks a ton.
Simer is cheaper
If you are not mounting it in the engine compartment, you can use the cheaper Simer pump. They are available for about $65 from BE Atlas in Chicago 773-283-2550. Do not use this pump in a compartment that will be exposed to gas fumes, it is not ignition protected. I put mine last week in one of the back seat storage areas. It works great.
Mikeski, What kind of boat do you have? I just got two of the simer pumps and am trying to figure out the best place to mount them.. I was thinking about putting them in a battery case and setting that inside my ski locker with one of the sacs they will be filling.
STR8JKT,
Here is a link to buy a Jabsco Ballast Puppy for $199 including the switch.
http://www.wakeboardboats.com/Phase4...?ProductID=116
