Anyone with a 2018 or prior Linc system in their boat know if it controls just the on/off power to the heater or does it control the fan speed as well?
On my G23 2017 on the LINC system it is a simple on/off only option . I wish you could adjust the fan speed but it is not an option at least on my boat. I understand your concern, seems like it would be simple to adjust the fan speedOriginally posted by PatM View PostAnyone with a 2018 or prior Linc system in their boat know if it controls just the on/off power to the heater or does it control the fan speed as well?
Just powers it on from the panoray screen under climate prompt. I guess it is in the high fan speed postion , but I never gave it any thought since it was just on/off anywayOriginally posted by PatM View PostThat's what I though. Do you use a separate fan speed switch or do you just power it on and it is in the high (assuming) fan position?Last edited by GMLIII; 04-04-2019, 03:12 PM.
You will have go into dealer settings on your panoray screen to check the heater box ( ie Y or N). Currently your panoray screen is programed for "No Heater". I don't know how to go into dealer settings and you may need some type of code to access, but it will be required I do believe to complete your heater installOriginally posted by PatM View PostThanks GMLIII. Installing a heater and this answers a lot of questions.
That is all correct. You will need the dealer code to get into that menu in the LINC. From there, it's a simple Yes/No. There is no fan speed control.
Can you share the LINC code for the heater? I’m installing my heater tonight and would love to take it out tomorrow.
