Linc control of heater
  • PatM
    • Jul 2013
    • 21
    • Little Alum Pond
    • Brimfield, Ma
    • 2018 Ski Nautque Team 200 CB
    Anyone with a 2018 or prior Linc system in their boat know if it controls just the on/off power to the heater or does it control the fan speed as well?
  • GMLIII
    • May 2013
    • 2817
    On my G23 2017 on the LINC system it is a simple on/off only option . I wish you could adjust the fan speed but it is not an option at least on my boat. I understand your concern, seems like it would be simple to adjust the fan speed
    • PatM
      • Jul 2013
      • 21
      • Little Alum Pond
      • Brimfield, Ma
      That's what I though. Do you use a separate fan speed switch or do you just power it on and it is in the high (assuming) fan position?
      • GMLIII
        • May 2013
        • 2817
        Just powers it on from the panoray screen under climate prompt. I guess it is in the high fan speed postion , but I never gave it any thought since it was just on/off anyway
        • PatM
          • Jul 2013
          • 21
          • Little Alum Pond
          • Brimfield, Ma
          Thanks GMLIII. Installing a heater and this answers a lot of questions.
          • GMLIII
            • May 2013
            • 2817
            You will have go into dealer settings on your panoray screen to check the heater box ( ie Y or N). Currently your panoray screen is programed for "No Heater". I don't know how to go into dealer settings and you may need some type of code to access, but it will be required I do believe to complete your heater install
            • charlesml3
              • Jan 2008
              • 2479
              • Lake Gaston, NC
              • 2022 G23
              That is all correct. You will need the dealer code to get into that menu in the LINC. From there, it's a simple Yes/No. There is no fan speed control.
              • PatM
                • Jul 2013
                • 21
                • Little Alum Pond
                • Brimfield, Ma
                Great. I do have the code from the dealer. They were more than happy to not have to install this for me at this busy time of year.
                • dDavid
                  • Feb 2010
                  • 22
                  • Henderson, KY
                  • 2014 G21
                  Can you share the LINC code for the heater? I’m installing my heater tonight and would love to take it out tomorrow.
