Original Teleflex Digital Gauges
There is a known issue with 2000 - 2002 digital speedometers and tachometers that were installed in Nautique boats. These gauges, manufactured by Teleflex, are known to have their displays fail. There is no generally-accepted repair procedure, and the only option to restore functionality is replacement. Unfortunately, Teleflex no longer manufactures this particular gauge, and there are no others made that are a close match.
It is important to note that on these boats, the engine hours are stored in these gauges, and when they fail, it is virtually impossible to verify the hours on the boat. If the boat came with Perfect Pass installed from the factory, the hours listed on that display may be accurate, however that system can be reset or modified, so keep that in mind.
There are replacement kits available from NautiqueParts that will convert your speedometer and tachometer from Teleflex to Faria gauges. These gauges are much more reliable.
When ordering the replacement kits from NautiqueParts, be sure to use the PLANETNAUTIQUE discount code PND for 10% off!
For an even easier repair, consider sending your dash to Silver Cove Marine for a complete gauge replacement. Instead of just replacing the speedometer and tachometer, SCM replaces ALL of the gauges, so that they match. All you do is send them your dash, and they send it back with all new gauges, and all of the wiring harness modifications complete.
Silver Cove Marine Gauge Replacement Service
This is the result of a Silver Cove Marine gauge replacement:
