Thats it . Two 1/2'' mounting bolts remove the complete unit . MARK the two halves of the housing then remove the three 7/16 bolts holding the two haves together. NOTE the pump assb can be installed upside down if that occurs it will not pump water . Either mark it before you remove it or remember the two hoses are on the engine side
That should be a simple 15 minute job. May take you a little longer on your first go-around. Man do I miss how easy it is to do an impeller replacement on a GT40. My Apex is a royal PITA!!2002 Ski Nautique 5.7 GM Apex
here's the one you need:
http://www.nautiqueparts.com/sherwoodimpellerkit.aspx2002 Ski Nautique 5.7 GM Apex
Hey guys I just thought that I would keep my business local and them order the impeller for my sheerwood pump. It came in today so I had my brother go and pick it up and he told me that is an emp replacement for the sheerwood. Has any one heard of them?? Are they worth getting??
