Ballast Install - where to find aluminum or ss piece
    • Feb 2026
    So many of you have mounted your impeller pumps on a custom aluminum (I think... maybe ss) flat piece that you have installed between the support bars behind the rear bench seat of your older SANs and SSs. Where did you get that flat piece of metal? I can find (and have) diamond plate, but I want a nice, strong, flat piece of aluminum that is wide enough for the 4 bolt pattern of the pumps, taking into account I will likely stagger them a bit.
  • shag
    • 2217
    Any machine shop or weld shop should have something. Possibly even as a 'scrap' or 'cut off' piece. Get it? Find a place and tell them you just need a little piece of aluminum flat bar... Might be able to get it free using the 'scrap' route.
    • wake_fun
      • 1330
      • CA
      • 1995 Super Sport
      Try this as shag said. Also, type in aluminum plate or stainless steel plate in google.........lots out there.
      Photo Album
      Ballast Install 1
      Ballast Install 2
      Amp Install
      PPass Install
      Alternator Install
      • TexanC3
        • Apr 2006
        • 66
        • Katy, Texas
        McMaster-Carr if you don't want to look locally.
        http://www.mcmaster.com/#aluminum-plates/=grtr5y
        • TxJole
          • Jun 2009
          • 898
          • Cedar Creek Lake TEXAS
          Metal Supermarket in Dallas
            • Feb 2026
            Thank you.
            • cjreents
              • Aug 2011
              • 10
              • Oregon
              • 1998 Air Nautique
              I second Metal Supermarket... I've used the one in Portland several times, they'll cut any size while you wait.
