man, now you've go me thinking again...looking only at the intake side, the cost of the 1 1/4" manifold system is ~ $122...three 3/4" system would be ~$86....so almost $40 less...now the question is which system is going to be simpler and more reliable overall...the cross manifold system would also be ~ 5" taller than the 3/4" system...i really wish I knew how much space I had down there...
if i do go with 3 3/4"...i'll buy 3 new fittings so i don't have the issues with the scoop and they would all match...
. spent all day yesterday basically gutting the boat and removing anything that had to do with the old factory ballast system including the through hull. i was thinking about cutting off the grates and scoop...but, now I think i'll just get one more 3/4" fitting. as easy as cutting the old one up would be...i'd rather have 3 matching fittings. i'll just fill the extra 2 screw holes with thickened resin and be done with. I've also decided to add the 2 new through hulls just rearward of the existing one. seems to be plenty of room there and makes the plumbing more compact. planning to bolt the pumps with rubber grommets directly to the fiberglass rr seat reinforcement...seems plenty strong to me. the last thing i figured out is where to mount the switches...i'm going to make a simple aluminum plate and mount it exactly where the factory knobs and switch was. now i just need some time to work...
