So after years of having the fuse panel installed in my boat I decided to change to a breaker panel. Once in a while I would have a fuse blow from a ballast pump, from sticking or whatever. You can see my original install from the link in my signature. As you will notice in my original install I installed the fuse panel and Perko switch on the side walkway wall. When I installed my heater I built a kick panel which put the fuse panel behind it
So if I ever had to change a fuse it sucked. I took everything out and reinstalled the new breaker panel and Perko switch on my kick panel. Now if anything happens I can just reset it and I can also turn the power to my items on or off. Also, now the Perko switch is easy to see and adjust.
