Originally posted by Drock
View Post
One things I would change in NN's design is that I would use a mushroom thru-hull if possible. If you already have a scupper in place and plan to use it, that's okay, but with a scupper you can't (or don't want to) empty while under way, as this will really strain the pumps. With a mushroom, you can empty underway, and if your mushroom is on the bottom of your boat, you can fill and empty when underway or at rest.
