I am building my ballast system currently and I ordered 1 1/4" Groco Bronze thru-hull scoop strainers for the intakes, but have since started to have second thoughts. I am using Jabsco ballast puppies as my pumps and am worried that if I face the scoop towards the bow I will ruing the impellars by forcing water through them when I am not running the pumps. If I face the scoop towards the transom, I will creat a bubble effect and not be able to fill while under power. Does anyone have any experience with these thru hulls? My other option is the Groco flush bronze thru-hull fitting but I am worried about debris getting sucked through the intake. Any suggestions?
Also, what approaches did people use to increase the diameter of the intake outflow of the jabsco pump from 1/2" to 1"? I have a set up in mind but was looking for other tried and true suggestions
Thanks
Eric
Thanks
Eric
