I am tired of having a great boat that feels underpowered for most of my activities. If I only wakeboarded I am sure it would be fine but I don't and I miss barefooting at comfortable speeds and miss a decent pull-up on my slalom ski. I have had more than 6 different props on my boat, changed the exhaust manifolds, and still find myself unhappy with the power available from the PCM 330ex.
Step 1 is to modify the FAE to a dual exhaust unit and remove the stock muffler. This should let the motor breathe as it did before I installed the FAE. It will also allow it to breathe more air as will soon be needed once I make the other modifications.
Step 2 option 1: Bolt on a Whipple supercharger
Step 2 option 2: replace the lower end of the motor with a HT 383 build
Option 1 is easier/quicker to implement but it costs significantly more and lower end engine failure is likely at some point in the future. Cost estimate is $7k, one weekend of work, one trip to Whipple Superchargers in Fresno for EFI mapping. This is a proven solution guaranteed by Whipple, expected results would be low 400's for horsepower and torque. I have received positive comments for going in this direction from at least one PCM employee that I trust.
Option 2 is cheaper but I will have to pull the motor to swap the components over to the new short block. Cost estimate is $4k, three weekends of work, and unknown hours of tuning to get the EFI tuned properly. Expected output to be about 400hp and 415+ ft. lbs. of torque from 2500-5000rpm. Note this is essentially the same as the new Indmar Hammerhead motor.
Step 3 would be to combine options 1 and 2 and have a motor with 500hp/500ft.lbs. on tap, but I don't think I really need that.
Here are the goals:
1. Pull a solid 34mph at less than 4,000rpms
2. Come out of the hole in wakeboard mode with a full passenger and full ballast load within a decent timeframe
3. Turn a small diameter prop to maintain a clean slalom wake
4. Pull a barefooter a solid 44mph
Out of all the props I have had on my boat the 644 and my current 1160 are not bad compromises when it comes to my goals but I am tired of compromising and I am ready to remedy the situation.
In some ways I feel like I am breaking new ground but I expect there will be quite a bit of interest in my results. I might even anticipate a group buy from Whipple or a motor builder if I can work out the details for this upgrade.
Thoughts?
Here are the goals:
Thoughts?
