Perko FlushPro - where to install?
  • jeclarke
    • Sep 2008
    • 57
    • Unknown
    OK all you experts,
    I just purchased a FlushPro for my model year 2001 Ski Nautique. I see 3 possible locations to mount it.
    1. between the water intake and the water stainer
    2. between the strainer and the transmission cooler
    3. between the transmission cooler and the water pump
    Which is the best location so it isn't touching the engine or near something that gets very hot.
    thanks,
    John Clarke
    • Sep 2026
    RE: Perko FlushPro - where to install?
    I put mine between the intake and the water strainer on my 99 Air DD. I have not used it yet, but I have had no problems running my boat... and no leaks yet.
    • Quinner
      • Apr 2004
      • 2246
      • Unknown
      • Correct Crafts
      No 1 is where mine is, it is pretty wide open there so makes accessing easy.
      • tadelfio
        • Oct 2007
        • 172
        • Bullard, Tx
        Throw it in the trash and don't use it all but if you insist, Do #1. Make sure everything goes through the strainer prior to entering engine. Just my two cents.
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          Number 1
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
