Connected the battery and garden hose, just a few little things needed sorting. Missed the transmission switch and the raw water hoses were on backwards. She fired right up after just a few turns. Re-checked all fluids after a 5 min run and they all needed topping up.
Getting ready for the final glass work, which includes the hole for the new pedestal. So drilled that and did a test fit. Will need to make a spacer as it’s about 15mm too long.
On ours only the screws along the back of the transom worked themselves out and would only be stopped by the swim platform. I used to tighten them up every few years. Once finished here, the deck won’t have any screws. It will only be bonded on with adhesive.
