Seems like everyone has spring fever and making moves to upgrade ballast. I have a 2015 210 and will be upgrading to the 750s and have researched this a lot.
Locker size:
Width 14 - 16" (wider towards bow and same as 230)
Length 53" (230 may be longer)
Depth 22" (230 May be deeper)
You will need to reinforce the dividers. It bows and jumps out of the small C channels. The middle reinforcement bar is at the 400lb bag level and you will need one higher for the 750lb. I am changing the bottom C channel to a taller L bracket or taller C channel to prevent bowing into the motor side. I am considering adding the panel reinforcement from Wakemakers but they will be on the bag side so I don't know how it will work (snag, rip, drag against bag). Additionally, I am getting a better pin to hold the panels down so they lock into place. They will want to lift as the bag fills (especially with reinforcements) and the pin is always falling out.
Plumping:
I am not plumbing bags to fill from overflow as shown on Wakemakers. They will fill and drain in parallel with the hard tanks. This configuration should eliminate the airlock issue. I have seen a few other solutions but I am opting to plumb the way the factory would on ballast upgrade.
My 2 cents. Happy boating.
					Locker size:
Plumping:
