'08 SAN 210 - which engine is this?
  • OneMoreSet
    • Aug 2011
    • 19
    • Calgary, Alberta
    Hi gang,
    Wondering which engine is this - obviously engine cover is removed so not immediately obvious to me - is it the 340 or zr6- are those 390hp?
    Cheers
  • OneMoreSet
    • Aug 2011
    • 19
    • Calgary, Alberta
    sorry guys, hanging problems uploading the pic - can figure that out...
    • OneMoreSet
      • Aug 2011
      • 19
      • Calgary, Alberta
      Okay, think i got it here , although its a really small pic - whats the max file size to upload?
      Hope its big enough to see...
      • wake_fun
        • 1330
        • CA
        • 1995 Super Sport
        Well, if it's a zr6 it would have closed cooling system.
        Photo Album
        Ballast Install 1
        Ballast Install 2
        Amp Install
        PPass Install
        Alternator Install
        • xlair
          • 694
          • Wisconsin
          that's a zr6
          2001 Pro Air Nautique
          • teamseal
            • Dec 2006
            • 416
            • Panama city, Florida.
            • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
            That is a ZR-6, Now to tell if it is a 409 or 390 hp motor take a look at the throttle body and if it is mounted to the upper intake with three fasteners it is the lesser hp motor. 4 fastners and it is a 409.
            • NCSteve
              • Sep 2011
              • 11
              • Gold Coast
              • 2005 Super Air 210 Team 2006 SV-211 Team 2007 Air 226 Team 2008 Super Air 230 Team 2011 Super Air 210 Team 2012 Super Air 210 Team
              If it is a confirmed 08 model it will be the 390hp, 409 was not released until 2009 from memory or maybe even 2010
              • teamseal
                • Dec 2006
                • 416
                That's funny I had a 08 with a 409!
                • OneMoreSet
                  • Aug 2011
                  • 19
                  • Calgary, Alberta
                  thanks for the resoponses guys!
                  Also out of curiosity, do the closed loop cooling engine typically use water or some mixture of antifreeze, or could you use antifreeze if you wanted to?
                  Cheers,
                    You use antifreeze mixture in the closed parts of the cooling system. Just like the tow vehicle.
                    • AirTool
                      • Sep 2007
                      • 4049
                      • Katy, Texas
                      Cheers,
                      If pure water is used, the boiling point will be too low and it will boil over/loose its coolant.
                      • srock
                        • Oct 2008
                        • 1147
                        Conversely you don't want 100% coolant either. Look at the manual. It will probably be a 50/50 mix.
                        • AirTool
                          • Sep 2007
                          • 4049
                          • Katy, Texas
                          Agree and never mix orange dexcool stronger than 5050 or it will turn jelly-like and leave a jelly coating. The chevy engines should use dexcool.
