Spare tire mounts... let's see um!
  • core-rider
    • Feb 2004
    • 1370
    • Huntsville, AL
    • 2003 Black SANTE
    I need to get a spare tire mount on my trailer. It's an '03 Ram-lin single axle. I've been looking at them everywhere but they all seem to only be made for 4 or 5 lug wheels. I need one for a 6 lug. I called Ram-Lin and they offer one for around $80, but I can get universal mounts for half that. Then just modify it to fit a 6 lug wheel. Anyway... let's see some pics of your mounts. I want to know where on the trailer they are and if there is any clearance issues I should be concerned about.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    The Ramlin mount construction and coating is much better than you'll get for half price + plus time spent making mods. Just pay the price and get one. You can order through your dealer and have it shipped to your house.
    I have an extra from Ramlin and sometimes think about selling it. Let me sleep on it.
    Here are some far away shots. If I visit the boat tomorrow, I'll get some close ups.
    • tdc_worm
      • Feb 2004
      • 535
      you're overthinking it. unless you and NEED 4, 5, or 6 lugs to keep you your spare from slinging off of your trailer (see the first sentence), all you need is a spare mount that will bolt to two holes on your rim.
      • Nautiquehunter
        • Jun 2008
        • 2099
        My Boatmate came with two bolt mount and is welded to the frame. I added a third stud because of the oversized wheels[18x10].
        • core-rider
          • Feb 2004
          • 1370
          • Huntsville, AL
          • 2003 Black SANTE
          I'm not trying to have lugs on every hole, I just don't know if a mount for a 4 or 5 lug pattern will be the correct spacing for a 6 lug wheel.
          AirTool, if you get anymore pics that would be great. We have the same trailers and I would like to see better where the mount is located. Do you ever have issues with the boat rubbing the spare on steep ramps when loading or unloading? Let me know about you mount also. Thanks for the help guys.
          Jason
          • wake_fun
            • 1330
            • CA
            • 1995 Super Sport
            Mine is up under the rear step.
            Photo Album
            Ballast Install 1
            Ballast Install 2
            Amp Install
            PPass Install
            Alternator Install
            • core-rider
              • Feb 2004
              • 1370
              • Huntsville, AL
              • 2003 Black SANTE
              I've seen that on a few other trailers and thought about making a mount. Can you get some better pics for me?
              Jason
              • Nautiquehunter
                • Jun 2008
                • 2099
                I believe EZloader puts the spare horizontally under the bow in the Y of the trailer. Boatmate only makes 1 mounting plate for the spare.
                The top and front holes for 5 lug the top and rear hole for 6 lug. I welded the rear hole closed and re drilled it to fit my wheel.
                • AirTool
                  • Sep 2007
                  • 4049
                  • Katy, Texas
                  I may not make it to storage today. I'm running way behind this weekend and weather here stinks. Might swing by tonight after a grocery run.
                  I have never hit the tire and don't see how I could. I've launched on very flat ramps and very steep ramps. I don't see how the boat could hit it unless you are way off the bunks - which would be bigger problems.
                  I think it does slightly impede swinging the tongue but I've never tried.
                  • BrennanK
                    • Feb 2009
                    • 348
                    • Hopkins, MN
                    I think he is wondering if the tire hits the ramp, as in bottoming out the tire/trailer. I think that would be more likely then the boat hitting it. The tire it mounted so far forward on the trailer that it should not hit the launch ramp, it is 3-4 feet from the hitch. That would be one scary ramp if you did drag the tire...
                    1997 Ski Nautique
                    • AirTool
                      • Sep 2007
                      • 4049
                      • Katy, Texas
                      He said "boat rubbing the spare".
                      • Latonkaboarder
                        • Jul 2007
                        • 372
                        • Mercer, Pennsylvania
                        • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
                        I have an EZ Loader trailer and mine is mouted like Nautiquehunter mentioned. I will try to get some pics of it soon. Just moved over the weekend and don't have my main computer unpacked yet. See if this link will work though. I like that it is out of the way and it is easy to remove, just one lug nut holding it there. Go to the third post down in the link and there is a decent pic of the trailer and wheel.
                        http://planetnautique.com/vb3/showth...tique-210-Team
                        Current: 08 Super Air 210 Team
                        Previous: 02 MC Pro Star 197
                        • 74green
                          • Nov 2009
                          • 281
                          • Canyon Lake, Texas
                          • 2001 Air Nautique
                          Location on Magnum trailer for my '01 AN
                          Current: 2001 Air Nautique GT-40
                          • AirTool
                            • Sep 2007
                            • 4049
                            • Katy, Texas
                            Here are some very bad pics.
                            • Latonkaboarder
                              • Jul 2007
                              • 372
                              Here is a couple of pics
