I am trying to add cupholder lights to my 2015 G21 and I cant figure out what kind of connector this is. I think I have seen some Deutsch connectors on the boat but these are definitely not them. Any ideas? Thanks
To me, it looks like a Molex part. Generally speaking only Moles, Deutsch & Amphenol -AMP (mostly compatible with Deutsch) use round terminals. I work for a company that builds some wire harnesses.
I did a search and it looks like this is a Molex MLX Series Connector
Link to series:
http://www.molex.com/molex/products/...wer_connectors
Link to what I suspect is this housing:
http://www.molex.com/molex/products/...P_HOUSINGS.xml
Link to what I suspect is the mating housing:
These are available through several distributors, one we use alot is Waytek, but they have a $35 min or $5 fee
Here is the link to the full series at Waytek:
https://www.waytekwire.com/manf/130/Molex/&sc=26
Good Luck
So it is a molex connector, I had a hard time navigation the waytek link above. I found them here
http://www.newark.com/webapp/wcs/sto...&storeId=10194
Once you have these connectors, was it just plug and play to add cupholders? Interested in adding these myself. Difficulty level or input would be appreciated! I have a 2015 230, but i think the wiring harness etc will be similar.Originally posted by JakebSo it is a molex connector, I had a hard time navigation the waytek link above. I found them here
Sent from my SM-G935V using PLT Nautique mobile app
it was super easy, I just bought one cupholder as a test which worked so I just bought the rest. It is pretty easy, hardest part is finding the wire harness as most of mine were tucked away in hard places to get to. You will also need
It is a little tedious to crimp these but not bad.
Some of my cupholders required a screw driver to pry out.
Mine are wired into the courtesy light switch in the LINC.
Happy that I was able to help. Sorry about the Waytek link, I also noticed that have a to min qty on these housings.
There are some relatively inexpe dive crimpers for pins like this. If there is a combined need for enough units, I maybe could put some pigtails together for this since we have crimpers available.
Sent from my VS995 using Tapatalk
I maybe interested in this! Let me know if you get more interest to come up with a price.Originally posted by Dandy21Happy that I was able to help. Sorry about the Waytek link, I also noticed that have a to min qty on these housings.
I have a plug at each cup, if you don't have courtesy lights you should find a bunch
I should have asked earlier, what AWG (ga) is the wire going into these plugs. In addition, if anyone knows, what AWG wire is on the LEDs that most of you are connecting to?Originally posted by JakebI have a plug at each cup, if you don't have courtesy lights you should find a bunch
Also, which wire is the 12 VDC + and which is the ground? I would assume that blue is 12 VDC +, but I have been wrong before.
Pretty sure it is 16 ga, my test I did was blue + and it worked like a champ. If you order the parts linked above it should work. Only thing not mentioned is I got my cups from Nautiqueparts.com
Thanks, do you recall what the wire AWG is on the cup holder? I am going to put a couple wire plug sets and send them to Guntersville for trial. I want to make sure that the splice connectors mate the correct size wires.Originally posted by Jakeb View PostPretty sure it is 16 ga, my test I did was blue + and it worked like a champ. If you order the parts linked above it should work. Only thing not mentioned is I got my cups from Nautiqueparts.com
Im out of town till Friday, I can check then. If you need faster you could probably call Nautique parts
