LED questions
  • seveet
    • Oct 2014
    • 185
    • Muskegon, MI
    • 2015 SAN 230
    LED questions
    I saw this on wakeworld. Interesting idea. I have some interest in adding something like this. For those of you have done this (1) what source are you tapping into to run the power especially for those that have the link systems? (2) Is there existing wiring that I can tap into? (3) What are the problems with this setup?
    http://www.wakeworld.com/forum/showthread.php?t=806561
  • Full-Force
    • Sep 2011
    • 84
    • Spartanburg, SC
    • 1996 Ski Nautique 176
    Well idk what others are tapping into but if it were my boat I would be tapping into the factory light switch because after all you only want them on when its dark anyway. If the extra current draw is a concern just use the factory light switch wire as the signal wire to a relay.
    pin 30 - 12v from battery(use a fuse and you can also tap into this circuit in dash where a constant hot wire is usually a heavier gauge wire)
    pin 85 - ground
    pin 86 - light switch
    pin 87 - to whatever accessories you want to power up
    • enzo thecat
      • Aug 2010
      • 226
      • Lake Wawasee among other places
      • 2026 G23
      The question I always have when I see these setups is; don't all the extra lights attract a lot of bugs at night?
      2026 G23 SuperAir.
      • Laketexoma
        • Dec 2004
        • 463
        • Lake Texoma (Texas side)
        • 2025 G23
        Here are mine. I have had no problems with bugs. I cut acrylic on my router. https://vimeo.com/173816188
        2016 G23 H6
        2014 G23 550
        2013 G23 450 (Great boat)
        2000 SAN ( Loved that boat)
        • rlwagens
          • Feb 2008
          • 147
          • Michigan
          • 2006 SANTE 210
          I did that same setup in boat after making my own acrylic rings in my old boat and not being satisfied with the amount of diffusion. I tapped right into the courtesy lights, and have always done red and have no issue with bugs. As soon as I tried blue or turn on docking lights tho they come in mass. FYI, if you go this route use the 3/8 polyethylene tubing (it looks frosted, not the clear vinyl tubing) and then 3/8 nylon barbed couplers like this: https://amzn.com/B008TSTT34. You can find them for $1 a piece at Lowes/Home Depot. The 1/4 tubing inside the 3/8 is not strong enough and will kink not giving you a perfect circle, and the 1/4 aluminum round stock will leave a dark spot in the ring.
          • seveet
            • Oct 2014
            • 185
            • Muskegon, MI
            • 2015 SAN 230
            Thx. I appreciate the feedback. Does anyone have pictures of how you tied into the wiring.
            • nautiques4life
              • Jan 2009
              • 696
              • SoCal
              rlwagens.. those amazon couplers look good, what is the difference between the 3/8 and the 3/8x1/4.. is that length or internal size? Which did you use? Thanks
              • rlwagens
                • Feb 2008
                • 147
                • Michigan
                • 2006 SANTE 210
                This is the type I actually got. No ridge in the center so the tubing can be pushed together and looks like a continual piece and hides the barbed fitting. 3/8x1/4 is prolly smaller on one end to connect a 1/4 ID tube to a 3/8 ID tube. 3/8 would be what you want. If the barbed fitting is too long just cut a little off each end with a knife, only need 1-2 of the actual barbs on each side for it to hold.
                I'll snap some pictures next time I am out at night but again, I like it better than my old DIY rings.
                • nautiques4life
                  • Jan 2009
                  • 696
                  • SoCal
                  Nice... Where'd you find those?
