UNDERwater LED's
  • beach
    • Jul 2010
    • 245
    • Alabama
    • 2003 SAN 210
    Has anyone with a FAE used a boat plug light? They seem like a cool and easy way to add underwater lights, but I'm worried my exhaust will block all of the light.
    • shag
      • 2217
      That's a good question... I bet it would block the light, or a good portion anyway
      • Paxdad
        • Mar 2013
        • 775
        • Cumming, GA
        • 2008 210 SANTE
        Originally posted by shag View Post
        Paxdad, Are they the lumatech Sea Blaze 3's?
        Yes they are.
        2008 210 SANTE
        • Paxdad
          • Mar 2013
          • 775
          • Cumming, GA
          • 2008 210 SANTE
          Under way.Click image for larger version
Name:	Lumitec S3 wake.JPG
          2008 210 SANTE
          • 210Surfer
            • Jul 2013
            • 23
            • Frisco, TX
            • 2020 210 SAN 2003 210 SANTE
            I have both. I'm using the single and it sits just below the FAE on my '03 SANTE. It makes a pretty good glow even in murky Lake Lewsiville, TX. I'm thinking about switching to their three hole plug with a second light to get some more glow to the sides and use the middle hole for a regular drain plug so I don't have to remove it. As for the damage question, if you have hit something at that point of the boat, the prop and rudder have probably already taken most of the damage, so I'm not concerned about that.
            Also, just be aware that these will overheat in ambient air so they need to be in the water to turn them on. Consider that when wiring them up. I added a tower Nav light so I used the wire that still runs to the old nav location. I never have my nav lights on out of the water so it reminds me to turn it off.
            • shag
              • 2217
              Thanks for the info... I am going to find a pin out diagram for my 08' SAN and determine the pin for the 12v accessory button and wire the U/W lights to it..... I can't find the wire for it!
              • scarbs
                • Aug 2009
                • 450
                • Arizona
                • 2017 G23
                #22
                Not blue, but the Lumitech9s are pretty stellar...
ID:	491470 Click image for larger version
                2017 G23
                2012 210 TE
                1999 SAN
                1995 Sport
                1991 Sport
                • pSchwade
                  • May 2012
                  • 130
                  • Reno
                  • 07' 220 SANTE
                  #23
                  does anyone have the roswell nightwater pro's? they have pretty awesome stats, but 1k each is a bit steep to hope they work well.
                  • Wake.BC
                    • Jan 2016
                    • 423
                    • BC, Canada
                    #24
                    Don't have any pictures, but lifeform led 9s are super bright for the price. Just installed them this season
                    • scarbs
                      • Aug 2009
                      • 450
                      • Arizona
                      • 2017 G23
                      #25
                      [QUOTE=scarbs;n491468]Not blue, but the Lumitech9s are pretty stellar...
                      Correction...Lifeform9s, not Lumitech...
                      2017 G23
                      2012 210 TE
                      1999 SAN
                      1995 Sport
                      1991 Sport
                      • shag
                        • 2217
                        Having my underwater light bar made now... Can't wait.... Going to tryhttp://www.thebestfishinglights.com/boat-lights.html
                        He says he has a 30,000 lumen light!
                        • enofsinger
                          • Feb 2011
                          • 10
                          • Utah
                          #27
                          I just installed lights from www.liquidlumens.com on my 2016 g23. Im really happy with them. I bought cool white which start out at 10,000 lumens and they use a lens to focus and magnify the beam even more. They get wired directly to that battery using a special box that converts the current from 12v to 34v. Way bright. Remote turn on and off. Install took about 2 hours. I found this code that got me a discount LIQUIDLAUNCH2016 . Pics below
ID:	493592 Click image for larger version
                          • core-rider
                            • Feb 2004
                            • 1364
                            • Huntsville, AL
                            • 2003 Black SANTE
                            #28
                            [ATTACH=CONFIG]n493590[/ATTACH]
                            [ATTACH=CONFIG]n493592[/ATTACH] [ATTACH=CONFIG]n493593[/ATTACH]
                            Which model light did you o with? I think I'd prefer the wider angle of the Surfrider light. Just trying to determine which is in your pic. They look good!
                            Jason
                            All black 2003 SANTE
                            -- Southern Fried --
                            • enofsinger
                              • Feb 2011
                              • 10
                              • Utah
                              #29
                              I went with the pipeline's in powder-coated white finish. They do an excellent job of lighting up the water at a great distance behind the boat and they still spread light around better than I expected for the tighter beam angle... as you can see in the picture. We tried wakesurfing at night during my last trip to Powell and they light the entire wake up really nicely. Far better than any other light I have seen on my friend's boats.
                              • core-rider
                                • Feb 2004
                                • 1364
                                • Huntsville, AL
                                • 2003 Black SANTE
                                #30
                                How long did they stay lit while surfing? Their site says they are not made to run out of water and will trip their overheat circuit if left for too long. Not that I'll really use them for surfing as I don't really do it, but just curious.
                                Jason
