WS-420 Throttle Location Install
  • mcfr741
    • Mar 2010
    • 41
    • 2008 236 SANTE
    I have seen pictures on the Earmark site under the install section where they have mounted the WS-420 near the throttle, on that plate that holds the bilge pump switch that gives power to the dash.
    It Looks really CLEAN!!!
    Has anyone installed it like this? Is there a bracket that needs to be built?
  • sstexan
    • Jun 2006
    • 230
    • 1999 Super Sport GT40, NDT 2007 236 Team
    I installed my 420 right where your talking about. My boat is a 2007 236 team. You will have to cut out the area and trim the bilge switch backing. I actually moved my switch and light over a few inches. You need to make sure you put some type of waterproof barrier on top as water can get into that compartment from the cup holder and the hydrogate area. I also moved my sub like the 2009 model has. It sounds great, of course I added 2 new Wetsound amps as well so that may be a little reason why it sounds so much better. Pics below.
    • mcfr741
      • Mar 2010
      • 41
      • 2008 236 SANTE
      That is exactly what i want to do, and I have the same exact boat, just diffrent color. I have not taken that plate off yet to look behind it so this may seem ike a stupid Question. Is there something inside there to support the 420? How difficult was the install?
      • TRO
        • Mar 2009
        • 410
        • Houston, TX
        i'm actually thinking about pulling the trigger and buying a WS 420 tonight...
        • NautiDave07
          • Mar 2008
          • 333
          • Louisville KY
          • 00 SAN210 07 236 TE
          where did you get the plate the sub is mounted to?
          00 SAN 210 (previous boat)
          07 236 te sold
            • Aug 2026
            Stop thinking about it and do it! It is an awesome upgrade and not a terribly expensive one.
            • kaikane
              • Sep 2008
              • 47
              • San Francisco, CA
              Ditto on that Sub Mount...I have a 2008 236 and want to do the same sub relocation. Did you get that from Earmark?
              • TRO
                • Mar 2009
                • 410
                • Houston, TX
                well, i ended up purchasing a new box anchor instead. the WS-420 is next on the list. i'm going to detail my boat this weekend and check out how I have everything wired and what amps I have and then figure out how to rig up the 420. hopefully, i can order it this weekend also.
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  Got my WS 420 BUT??
                  How in the heck do you get these panels off? Scared to pull really hard on any end? Little help please!!!
                    • Aug 2026
                    What panels?
                    • sstexan
                      • Jun 2006
                      • 230
                      No, I had the sub enclosure custom made in Houston. The panel actually never came off. The top where the hydrogate comes off with a couple of tabs and the drink holder comes out. I also took the 6.5" speaker out to get to everything behind the panel. Everything pretty much screws into the side panel. The sub actually sounds better than it did inside the storage compartment. PM me if anyone has more questions. Good luck!
                      • Nordicron
                        • Sep 2009
                        • 557
                        • Madison, WI
                        Thanks for the guidance! I will try this approach tonight and hopefully take some pics in the process!
                        Also I am extremely interested in that submount!!!! Would love to get my sub out of the passenger port storage!!! Earmark are you listening??? Any chance that one could be made and shipped?
                        • Nordicron
                          • Sep 2009
                          • 557
                          • Madison, WI
                          Smarty
                          What panels?
                          I think I meant combing pad. Stiil how the heck do you guys get these off?
                          • Latonkaboarder
                            • Jul 2007
                            • 372
                            • Mercer, Pennsylvania
                            • 81 Ski Nautique when growing up 2007 SANTE 210 2008 SANTE 210
                            I did the same install on my 08 210. To remove the panel you have to first remove the throttle lever. There is a small allen head screw on the underside of it and also a screw on the nuetral button. After you remove the throttle you just pull on the panel. I started on the top and worked my way around. It is held in place by those automotive style push pins. Once you remove the outer panel you can remove the grey colored plastic panel. It is held on by some small phillips head screws. Then you are ready to begin the fabricating. It is pretty easy, just measure twice and cut once to the size of your WS 420. I didn't really see anything behind that panel to mount the WS 420 to so I just made mine a snug fit and used a bead of silicone to hold it in place. Just make sure you let the silicone set up before you try mounting it back in. I also moved my master disconnect switch and light as previously stated. It is a fairly easy install. I don't think I have any pics of it but will try to get some for you.
                            Current: 08 Super Air 210 Team
                            Previous: 02 MC Pro Star 197
                            • Latonkaboarder
                              • Jul 2007
                              • 372
                              Christmas tree plugs
                              Here is a pic of the plugs they use to hold the panel on. Whitelake carries them if any were to break.
