I am planning on doing some upgrades to my stereo in the spring and adding a amp is one thing. I plan on running 0 guage wire to a distribution block to run the 3 amps. My question is, how long does my power wire have to be from amp to battery. I would measure for myself but boat is in storage and I can't get to it. The boat is a 2008 210 I assume 20 feet of wire would work but Im not sure of all the angles and corners to get to it.
RE: Power Wire
Since 0 awg is so expensive, you really only need 6 feet each of power and ground to get to the battery on the amp side. All you have to do is run it down the sidewall of the boat, super easy.
RE: Power Wire
check out this website for good cheap cable http://www.knukonceptz.com/. i personaly dont think 6 feet is enough. you really need to go measure and make a decision depending on the setup you want to build and what ever you decided length is add five extra feet of just in case wire.
RE: Power Wire
Wow - 1/0 wire - that can carry enough current to power something like a 150 amp panel. Does a boat with three amplifiers potentially draw that much current? Is it possible to get 150A out of a battery(s)?
Just curious2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
I like to go overkill on things, it can't hurt anything and if i ever want to go with a crazy system I will be ready. My next question is where are the batteries mounted in my boat. I know stupid question, but I haven't even got to look inside my boat yet.2008 SANTE 210 Orange Baby! Current
2007 Gekko GTO22 Previous
You probably can't tell in my pic, but I used 0 gauge wire off pos. and neg on the battery (with a huge 200amp fuse) to the capacitor. Then used 4 gauge into two distribution blocks tucked above the amps. I know it never hurts to have extra wire, but having a few extra feet of 0 gauge can definitely get in the way.
