I have a 1999 Air Nautique direct drive. It has the small rear compartment behind the bench seat. The previous owner did quite a bit of custom work on the boat's audio system, but he used mostly car equipment. As a result, I am pulling most of the equipment out and replacing it with marine equipment. At any rate, 1 of the things he did was to add 2 extra batteries to the sound system. There is a perko switch, but no isolator. I will be adding an isolator, but I digress. He built a custom housing out of carpeted MDF (not glassed, so it's not in great shape now) in the rear storage compartment for the 2 extra batteries, which is great for the added weight/wake, but effectively eliminated the usefulness of this storage area. I have pulled the batteries and the custom housing/floor out of the rear hatch.
Question 1: If I want to move the 2 batteries, any better ideas on placement? I don't want to lose space under the observer seat. Has anyone put 1 or 2 batteries further up under the bow seats? My main battery is under the nose cushion in the bow. I was thinking about putting the 2 extras under the other bow seats (1 each), but I cannot recall if that is a flat bottomed area. Also, unless I change the configuration, I may need a set of long battery cables to thread from one side of the bow to the other. Any ideas where to obtain?
Question 2: When I took out the custom housing in the rear hatch, what was left was direct access to the hard ballast tanks. Does anyone know if there is supposed to be some separator flooring or board or something between the tanks and the storage space? If not, has anyone built anything to accomplish that? Alternatively, has anyone beefed this up to accomodate a fat sack? I would like to use the area for storage, but have the option to throw a fat sack in there and add another 400 - 800 lbs of ballast, but I don't want to damage the hard factory ballast tanks. Anyone have any ideas for what materials to use to build a strong separator floor that accomodate a lot of weight and not crush the tanks below?
Question 3: Has anyone removed the hard factory ballast on a 99 Air or Sport and added a custom automatic (pump driven) ballast system. Is it difficult to do for someone with only moderate mechanical skills? The ballcock system works on mine, but it's basically a full ballast or empty ballast option. There is nowhere near the amount of control needed to do small tweaks on this old system.
Thanks in advance. I'm going to take some pictures this weekend of the boat (which is currently torn apart as I am going to be having the interior re-vinyled) and log my progress on this restoration/customization process.
