2003 Super Air Re-Do
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • Steamboat Springs Colorado
    • 2003 210 SANTE
    Does anyone happen to know....besides the normal correct craft sights.......where I might be able to find the cup holder MOLD that hold the bow cup holders? The old ones have some minor cracks.....that I might repair....if I can't find another set. Thanks D
  • Rockymtnsurfer
    • Nov 2017
    • 404
    • 2003 210 SANTE
    • t.franscioni
      • Jun 2014
      • 715
      • United States
      • 2002 SANTE
      You’ll have to wait for someone to part out their wrecked boat for something like that. The plastic vinyl covered cup holders, dash and drivers side console are all very rare pieces and will take some time come across in my opinion. Best bet is to repair.
      • Rockymtnsurfer
        • Nov 2017
        • 404
        • 2003 210 SANTE
        sounds good....thanks....I thought I was nuts......repair will be the way to go. Thanks again
        • wakejunky
          • 679
          • Ca
          • 2003 SAN
          Good luck getting them out. It is really tight back there.
          • t.franscioni
            • Jun 2014
            • 715
            • United States
            • 2002 SANTE
            Agreed. It’s tight. I got mine out but I had to pull the entire bow backrest out and it’s very flimsy you’ll want to be careful not to break it when lifting it out. If you run into any issues post it here I can share with you my experience removing it if need be. There was some screw hidden under the vinyl and under the foam that were holding it in and needed to be found and removed which was a little time consuming.
            • Rockymtnsurfer
              • Nov 2017
              • 404
              • 2003 210 SANTE
              My whole boat is in pieces Skins being made...about to gel coat interior hull.......they came out when I took all the padding etc. There was that hidden screw you were talking about! Thanks again guys D
