Does anyone happen to know....besides the normal correct craft sights.......where I might be able to find the cup holder MOLD that hold the bow cup holders? The old ones have some minor cracks.....that I might repair....if I can't find another set. Thanks D
You’ll have to wait for someone to part out their wrecked boat for something like that. The plastic vinyl covered cup holders, dash and drivers side console are all very rare pieces and will take some time come across in my opinion. Best bet is to repair.
Agreed. It’s tight. I got mine out but I had to pull the entire bow backrest out and it’s very flimsy you’ll want to be careful not to break it when lifting it out. If you run into any issues post it here I can share with you my experience removing it if need be. There was some screw hidden under the vinyl and under the foam that were holding it in and needed to be found and removed which was a little time consuming.
Skins being made...about to gel coat interior hull.......they came out when I took all the padding etc. There was that hidden screw you were talking about! Thanks again guys D
