Installation help: CoverSource cover for 2007 SV-211
  • jhoffy22
    • May 2020
    • 112
    • Ohio
    I received my cover from CoverSource and am really happy with the design and craftsmanship. However, I can't figure out how to secure the drawstring portion in the rear. How does the cinch work?
    Thanks in advance.
  • SilentSeven
    • Feb 2014
    • 2108
    • Bellevue WA
    • 2004 Nautique 206
    The tightening strap shown loose on the swim step has small rope parts on each each. Those rope parts should tie to the cover drawstring ends you can see hanging at each end.
    Once tied, loosen the draw strap by opening the mechanical one way locking device. Before tightening, make sure the strap is below the gunnel line. Then to tighten, pull the strap end across the back end of the boat perpendicular to the transom using the mechanical device for leverage. You should be able to get the strap really right. Make sure the pad is between the lock and the transom.
    I'll see if I can take a picture of mine later today.
    Hope this helps.
    If you don't mind me asking, how long did you wait for your cover once ordered?
    Bellevue WA
    • jhoffy22
      • May 2020
      • 112
      • Ohio
      Hope this helps.
      Thanks for the info. A picture would be great.
      Ordered June 10, 2025 and received March 10, 2026. Worth the wait.
      • SilentSeven
        • Feb 2014
        • 2108
        • Bellevue WA
        • 2004 Nautique 206
        Here you go!
        https://youtu.be/8j8BVIup89k?si=-lrPFpphL25XRaDY
        Bellevue WA
        • em
          • Jun 2021
          • 9
          • Kamloops BC
          • 2005 SV211
          There is a bit more install information in this thread https://www.planetnautique.com/vb5/f...ion-guide-help
          I am also looking for that installation video but it's gone from youtube.
          • MN Ryan
            • Aug 2020
            • 1386
            • Maple Grove, MN
            • 2007 SV-211 TE
            Is there anything specific you're struggling with? Mine is in storage for a few more weeks, but I have a lot of practice putting the cover on a 211. :)
            • SilentSeven
              • Feb 2014
              • 2108
              • Bellevue WA
              • 2004 Nautique 206
              Most important thing is to correctly do the rear stern ties so you get the one pull release. You're hating life if you do it the other way. :) I can make another vid for anyone that's interested.
              Bellevue WA
              • MN Ryan
                • Aug 2020
                • 1386
                • Maple Grove, MN
                • 2007 SV-211 TE
                Sounds like personal experience!
