Throttle Base Assembly Troubleshoot and Replacement
  • Scooter G
    • Jan 2022
    • 1492
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Thanks for the feedback, if JP stills wants a crack at it might be worth having a backup down the road. Glad the new one is working good, that's promising.
    I may peel the lid on mine when the new one gets installed, just to see if it's as simple as a smoked diode, it's an easy test.
    • TDR
      • May 2020
      • 8
      • Pittsburgh PA
      • 2001 Sport Nautique replaced with 2017 SN200CB 2016 Malibu 23LSV
      2017 SN200 CB : My issues are different.
      1. occasionally does not go in forward gear. stated last 2 days of skiing. today was testing with ~100 in gear attempts and 7 no forward
      2. more frequent when engine is warm say 5 in the last 20 and none until 2 ski run simulations
      3. no weird sounds at throttle body like clicks mention by aerojust but not hearing or feeling the normal umph of ingear
      4. neutral button does not work
      5. when warm, the connections at transmission are soften and barely require the tab be lifted over the dimple
      Could this be something else?
      Why is just occasional?
      For my model and year, part is different and 170158. The label on mine ends in 70 while nautique parts label looks similar but ends in 77. Have an email into nautiqueparts.
      • twollenweber
        • May 2024
        • 2
        • Columbia River
        • Kent, Washington
        • 2016 Nautique 200 DD
        The “text” support from Nautique Parts was amazing for me. I’d double check with them. Everything you’re saying says to me it’s the throttle base. Remember to get the template and print that out. You will have to cut out the fiberglass to fit the new part. A good Dremel or similar tool is the best way.
        • LKskier
          • Feb 2021
          • 1
          • Australia
          • 2014 200
          I'm having the same issues as you - 2015 200 with 343. Hoping someone here might help. Not sure I want to spend the money on a part before I know it is the problem. Have you swapped your connections around to test? Ie: reverse will be forwards and vice versa and will rule out the solenoids as an issue. I'm about to try some connection cleaner but I doubt that will help tbh. Would love to know what is inside that control box to see if it is serviceable?
          • awhitehead
            • May 2025
            • 0
            • San Clemente
            • 2020 G21
            Originally posted by aerojust View Post
            Here is my experience with a faulty Throttle Base Assembly in my 2020 SAN 230. This should apply to all newer Nautiques that use a Livorsie Throttle Base "Fly By Wire" http://www.livorsi.com/catalog/contr...emount_ski.htm. This unit electronically sends both throttle position and transmission gear (reverse, forward, and neutral with the neutral switch). There are no throttle or transmission cables in the newer boats. I think this started in 2015, but do not quote me on this.
            This is the part I am describing: -
            https://nautiqueparts.com/throttle-base-assembly
            The issue presented itself last season in two ways. First, sometimes the boat would not crank. Everything looked good. This would normally happen when you shut down on the water after some use. A quick joggle of the throttle in neutral would allow it to crank. At this point, it was not a big issue as it only happened once in a while and it always started after the jiggle. Honestly, I did not know the boat was fly-by wire and assumed that the throttle cable may be needed to be adjusted or some other issue, hence the jiggle should always fix it and I would worry about it over the winter. Second, the neutral switch did not work. I have never used this to rev an efi boat, so I was not planning on spending the money or time to fix it. I did not know at the time they were connected.
            This season the same issue got worse to where I had to play with the throttle for minutes to get the boat to crank. I could also hear the throttle base clicking like a solenoid. The clicks were not predictable and sometimes it would half-click. I can describe it as a dirty slow click. This is when I started to do the research. I pulled the box out and confirmed the clicking was coming from the box. I adjusted the neutral (set screw closest to the throttle) and it seemed to get a little better, but still was not reliable. This is when I called and spoke with Fred at Livorsi. He said that if you can hear it click it is dying. Livorsi will rebuild it for about 1/3 of the price of a new one, but that has a few weeks or more lead time. I think talked to Nautique Parts to ensure the throttle bases have a current manufacturing edition. I read in a few places that the newer versions are less prone to fail, not sure if this is true or not. My new one was stamped with 2023 in the serial number. I installed the new assembly and all is good, plus this resolved the neutral switch issue.
            This is the process I used for the install
            Disassembly.
            1) Remove the top trim piece where your armrests and has the quick control buttons and knob. I did not fully remove this as the last clip at the back was still in. I think I may have had to pull a large backrest trim cushion off to get this all the way off. I could swivel it out of the way with no issues still attached at the back.
            2) Unplug the quick control/knob wire harness so you can swing the trim our of the way.
            3) Remove the Throttle Handle. Pop off the plastic nautique logo covering the allen head screw. Unscrew the allen head and the throttle handle pulls out and away
            4) Remove the Side Trim piece that partially covers the black plastic around the throttle.
            I used a trim pry tool i have for my vehicles to do this. you could also use a screwdriver, just be careful not to scratch the gelcoat where you can see it and to not bend too much as you do not want to break the trim backing.
            5) Remove the screws on the hard plastic trim around the throtte. Mine had a few at the bottom and a few at the top where you tool off the armrest trim
            6) Remove the throttle base. Mine had a screw into the fiberglass on the upper rear and 3 botls on the other 4 corners. At first I did not realize they were bolts and stripped one out. Mine were course thread 20-24 botls.
            7) unplud the throttle base wire harnesses (2)
            Do everything in reverse to put it back together. Some notes on this:
            1) Make sure you plug the quick control button and knob back it
            2) I have read elsewhere that you may need to adjust the neutral set screw (one closest to the throttle lever) This would to be hard to adjust once in place, maybe you can get to it. I dd not have to adjust mine, but I did screw the throttle lever back on to test it out before I mounted it.
            3) Make sure that the number of clips on the trim is the same as in the fiberglass - my trim had an extra clip and I did not realize this until I had it partially mounted. I had to remove it to figure out why it was not working properly.
            4) I would buy some new clips, I reused some, but some were pretty bent.
            5) When pushing the clips into the trim before mounting I used the closed part of a 9mm wrench to drive them down. It fit perfectly on the clip flange and allowed enough pressure to drive them in.
            6) You can also put the clips in the fiber glass first. I am not sure which way is better. Maybe a mix of both depending on how they come out.
            Hopefully this helps someone in the future. Send me a message on here if you have any other questions about my experience.
            Very helpful, thank you. Ordered the new assembly from nautique parts with the discount, DIY wasn’t bad using this as a guide. Only a few moments of uncertainty and a couple broken clips. I was having the intermittent start issue last summer and this first trip after the repair was great. Click image for larger version
            • North Woody
              • Jun 2020
              • 147
              • Glencoe, IL
              • ‘20 Nautique GS22 1936 Chris Craft
              #21
              I had been having these same intermittent no-start issues on my 2020 GS22 this summer. It wasn’t bad initially, as all I had to do was jiggle the throttle a few times into/out of gear to get it to crank. However, it got worse over the summer so I had my Dealer look at during the winterization service before storing it. In the end, they found it to be this same faulty throttle base issue which needed replacing.
              FWIW, the bill totaled ~$1,200 (parts $900 and labor $300) which seemed pretty aggressive since it was out of warranty. Fortunately I had bought a 10-year extended warranty which covered 100% of the cost (minus my $50 deductible) so it all worked out fine. Hope this is helpful for anyone else who may be experiencing this same occasional no-start issue.
              • sengel
                • May 2019
                • 1
                • Regina, SK Canada
                • 2018 SAN 210
                #22
                jpwhit are you still refurbishing Throttle Control assemblies? Am from Canada and replaced mine last year from my 2018 SAN 210 - would like a back-up and thought of you - let me know - Steve
                • rwrose
                  • Oct 2020
                  • 17
                  • Lakemont GA
                  #23
                  This write up was extremely helpful, thank you. Sharing a pic of the disassembly for 2020 GS22 for others to reference. Not bad, you will definitely want some plastic harbor freight panel pulling tools.
                  • DocPhil
                    • Jan 2016
                    • 469
                    • Midwest
                    • 2016 G23; yamaha superjet
                    #24
                    Maybe I missed it in the thread but how much is it to have it repaired versus replaced?
                    • Scooter G
                      • Jan 2022
                      • 1492
                      • 2022 G23 ZZ8
                      #25
                      Where did I just see that DocPhil? I remember $150, but there was the down time between shipping and repair.
                      • DocPhil
                        • Jan 2016
                        • 469
                        • Midwest
                        #26
                        Good point. If only someone had a used and repaired one for sale. I would buy it.
                        • Azmouse76
                          • Mar 2016
                          • 3
                          • Phoenix Arizona
                          • 1987 Ski Nautique
                          #27
                          I replaced my Throttle Base Assembly and contacted Livorsi to repair the original. They replied "Most repairs will run 4-5 hundred dollars".
                          • DocPhil
                            • Jan 2016
                            • 469
                            • Midwest
                            #28
                            What? Lol. Sounds like new is the way to go then. Good off season project as long as she doesn't fail on me!
                            • kylant
                              • May 2010
                              • 558
                              • Lake Tahoe
                              #29
                              i think i may be starting to experience this. last night, shut the motor off, went to start, nothing. after jiggling, fiddling, it started. did it again while at the dock.
                              i am prepared though, i bought a throttle base preemptively. i have it in the garage. has anyone replaced one on a 210? just a bunch of clips, any screws/bolts on the paneling?
                              • kylant
                                • May 2010
                                • 558
                                • Lake Tahoe
                                #30
                                replaced mine yesterday. super straight forward, thanks to the previous posts. everything works as it should
