Throttle Base Assembly Troubleshoot and Replacement
  • aerojust
    • Jul 2020
    • 66
    • VA
    • 2020 SAN 230 Past 2000 Ski Nautique TSC1
    Here is my experience with a faulty Throttle Base Assembly in my 2020 SAN 230. This should apply to all newer Nautiques that use a Livorsie Throttle Base "Fly By Wire" http://www.livorsi.com/catalog/contr...emount_ski.htm. This unit electronically sends both throttle position and transmission gear (reverse, forward, and neutral with the neutral switch). There are no throttle or transmission cables in the newer boats. I think this started in 2015, but do not quote me on this.
    This is the part I am describing: -
    https://nautiqueparts.com/throttle-base-assembly
    The issue presented itself last season in two ways. First, sometimes the boat would not crank. Everything looked good. This would normally happen when you shut down on the water after some use. A quick joggle of the throttle in neutral would allow it to crank. At this point, it was not a big issue as it only happened once in a while and it always started after the jiggle. Honestly, I did not know the boat was fly-by wire and assumed that the throttle cable may be needed to be adjusted or some other issue, hence the jiggle should always fix it and I would worry about it over the winter. Second, the neutral switch did not work. I have never used this to rev an efi boat, so I was not planning on spending the money or time to fix it. I did not know at the time they were connected.
    This season the same issue got worse to where I had to play with the throttle for minutes to get the boat to crank. I could also hear the throttle base clicking like a solenoid. The clicks were not predictable and sometimes it would half-click. I can describe it as a dirty slow click. This is when I started to do the research. I pulled the box out and confirmed the clicking was coming from the box. I adjusted the neutral (set screw closest to the throttle) and it seemed to get a little better, but still was not reliable. This is when I called and spoke with Fred at Livorsi. He said that if you can hear it click it is dying. Livorsi will rebuild it for about 1/3 of the price of a new one, but that has a few weeks or more lead time. I think talked to Nautique Parts to ensure the throttle bases have a current manufacturing edition. I read in a few places that the newer versions are less prone to fail, not sure if this is true or not. My new one was stamped with 2023 in the serial number. I installed the new assembly and all is good, plus this resolved the neutral switch issue.
    This is the process I used for the install
    Disassembly.
    1) Remove the top trim piece where your armrests and has the quick control buttons and knob. I did not fully remove this as the last clip at the back was still in. I think I may have had to pull a large backrest trim cushion off to get this all the way off. I could swivel it out of the way with no issues still attached at the back.
    2) Unplug the quick control/knob wire harness so you can swing the trim our of the way.
    3) Remove the Throttle Handle. Pop off the plastic nautique logo covering the allen head screw. Unscrew the allen head and the throttle handle pulls out and away
    4) Remove the Side Trim piece that partially covers the black plastic around the throttle.
    I used a trim pry tool i have for my vehicles to do this. you could also use a screwdriver, just be careful not to scratch the gelcoat where you can see it and to not bend too much as you do not want to break the trim backing.
    5) Remove the screws on the hard plastic trim around the throtte. Mine had a few at the bottom and a few at the top where you tool off the armrest trim
    6) Remove the throttle base. Mine had a screw into the fiberglass on the upper rear and 3 botls on the other 4 corners. At first I did not realize they were bolts and stripped one out. Mine were course thread 20-24 botls.
    7) unplud the throttle base wire harnesses (2)
    Do everything in reverse to put it back together. Some notes on this:
    1) Make sure you plug the quick control button and knob back it
    2) I have read elsewhere that you may need to adjust the neutral set screw (one closest to the throttle lever) This would to be hard to adjust once in place, maybe you can get to it. I dd not have to adjust mine, but I did screw the throttle lever back on to test it out before I mounted it.
    3) Make sure that the number of clips on the trim is the same as in the fiberglass - my trim had an extra clip and I did not realize this until I had it partially mounted. I had to remove it to figure out why it was not working properly.
    4) I would buy some new clips, I reused some, but some were pretty bent.
    5) When pushing the clips into the trim before mounting I used the closed part of a 9mm wrench to drive them down. It fit perfectly on the clip flange and allowed enough pressure to drive them in.
    6) You can also put the clips in the fiber glass first. I am not sure which way is better. Maybe a mix of both depending on how they come out.
    Hopefully this helps someone in the future. Send me a message on here if you have any other questions about my experience.
  • gonefishin5555
    • May 2018
    • 114
    • SoCal
    • 2017 GS22
    I did this part swap on my boat me and boat partner took less than an hour to do. I knew about this write up but we did the repair on the fly and didn't have any problems. I had bought some replacement clips but we didn't use them. The part we removed was dated 2020 but installed summer 2021 so it only lasted two years
    • jpwhit
      • Aug 2016
      • 656
      • Cary, NC
      I've never had a boat with one of these Throttle Base Assemblies, so I've never opened one up to see what's going on in there. But I'm very experienced with both electronic and mechanical repair. I have a full CNC machine shop setup in the basement, so I can even make most mechanical parts if needed.
      If anyone who has a broken one is willing to send it too me, I'll take a crack at fixing it. If it works, I'll send it back to them. I'm also happy to pay for the shipping both ways. PM me to work out details if interested.
      • aerojust
        • Jul 2020
        • 66
        • VA
        jpwhit Mine is just sitting here on my desk as a busted expensive paperweight. I will ship it to you to have a look. I am an aerospace engineer with some basic electronic experience. I think there must be something cooked on the board(s) inside. I am not planning on having it rebuilt. Let me know if you want it and I'll send it.
        • jpwhit
          • Aug 2016
          • 656
          • Cary, NC
          Sent you a PM with my address.
          • Speed_racer
            • Jul 2019
            • 7
            • Tahoe City California
            Given that boats are covered by 5 year warranty - would it cover the Throttle Base Assembly? And considering that the issue is intermittent - it happened to me 5 times so far - Does anyone have suggestions how to deal with the warranty - I bet the issue would not be reproducible at the shop - especially in a dry dock.
            Thoughts?
            • Waveslayer
              • Oct 2022
              • 73
              • CA
              • Mastercraft X9, G23
              Speed_racer I take videos on my phone always now! Especially in my cars, it has saved me more than once. Just did it yesterday with my Ram Uconnect BS again. That's my little 2 cents
              Sent from my SM-S916U using Tapatalk
              • zmnypit
                • Sep 2020
                • 158
                • Alabama
                • 2017 G23
                Old thread I know but did anyone ever rebuild one of these? Livorsi said they would rebuild it for me in roughly 3 weeks but I have Amazon and all the electrical parts needed to DIY this if I knew which part was bad. Its already apart and ready to go
                https://www.themalibucrew.com/index....-2014-23-lsv/&
                • Scooter G
                  • Jan 2022
                  • 1471
                  • On a Lake in Idaho
                  • 2022 G23 ZZ8
                  Doesn't it look like the majority of the average are pointing to a fried diode.
                  Do you have a visual on the circuit board for anything that looks toasted?
                  "If it blows again, try a 1N5401 for 3 Amps capability instead of the 1 Amp of the 1N4001." (from the Malibu Thread).
                  My neutral lockout button has never worked, but no other issues than that (yet).
                  • wils_26
                    • Oct 2020
                    • 4
                    • MN
                    Thanks, everyone. I think I have to do this repair soon on my '17 GS20 or have the dealer do it based on the "no start" issues we had last week on the water and looking thru the threads. Has anyone else out there had success doing this repair on their own with the $580 NP part plus taxes, shipping, and fees for a GS20 recently?
                      • 17134
                      If you order the part, be sure to use our discount code (PND) for 10% off at NautiqueParts. At least that will save you a little bit.
                      • wils_26
                        • Oct 2020
                        • 4
                        • MN
                        I used the discount code. My Nautique dealer (MarineMax) tells me the part is backordered so I am glad I have one. Thank you, Jeff!
                        • twollenweber
                          • May 2024
                          • 2
                          • Columbia River
                          • Kent, Washington
                          • 2016 Nautique 200 DD
                          I’m new to this forum, but right away I already found what I was looking for. I’ve got a 2016 200 OB, and the electronic neutral switch has never worked since I bought the boat. Thanks for the detailed instructions, I feel like it should be pretty easy, my only question is about the new part. I was told I will have to file away some of the fiberglass on the back side, by the support at Nautiqueparts. Has anyone had to do that as well?
                          • Scooter G
                            • Jan 2022
                            • 1471
                            • 2022 G23 ZZ8
                            jpwhit, how did the repair go with aerojust and his lame Throttle Base, were you able to make it headway there?
                            twollenweber, I saw the possibility of a fiberglass modification, did you have to do anything here? Any tricks or hacks you could throw this direction would be greatly appreciated.
                            My throttle base should be here by this weekend. In addition to aerojust's write up, I'll follow up.
                            I will give Nautique Parts a plug, they shipped the part the same day I placed the order, nice job NP.
                            • aerojust
                              • Jul 2020
                              • 66
                              • VA
                              It did not go. Fully forgot to send it out.... My bad. It is probably laying in my garage is still interested let me know.
                              The new one has been flawless.
