How I fixed my PerfectPass display (for free)
  • jkallen21
    • Jan 2013
    • 401
    • United States
    • 2006 Super Air 220
    Many of us have seen the issue where the PP display becomes unreadable due to excessive moisture. The problem has moved from annoying to very expensive because the components aren't available anymore so no new ones can be made. I've had it happen on 3 displays now and the latest one was because the boat sat all winter with the cover on but outside and the repeated rain and sun caused the issue (along with two ballast gauges that also died). The solution from PP today is to buy a GPS model that will run almost $1000. I removed by gauge from the dash and tried to understand how to take it apart. Sadly, this is not possible the chrome edge around the display is compressed and molded on. I did cut the chrome edge off of an extra one I had and got a look inside - and there are some possible areas where the touch of a hot solder gun might yield some success, but you'll forever have a chrome edge with a cut in it.
    While I have mine out, a friend of mine suggested putting some of those silica packets inside of it (the ones that come inside of a vitamin bottle or an electronics package). the gauge has a hole large enough on the back to insert a smaller-sized packet, so I did. I also taped a larger one to the back of the gauge. I then let it completely dry out by leaving it in an air-conditioned house for about two weeks. I ran it all summer and never had another issue with it.
    I really hope this helps some of you too.
  • MTRBTR
    • May 2012
    • 485
    • MT
    I love stuff like this. Thanks!
    2006 SV 211 (Sold)
    97 Sport Nautique (Sold)
    89 PS 190 (Sold)
    75 MFG (Sold)
    • rolleronariver
      • Feb 2017
      • 21
      • Rogers, AR
      • 92 Sport Nautique
      Do you have any pics of this process?
      • jkallen21
        • Jan 2013
        • 401
        • United States
        I’ll post some pics soon. Need to get back up to the boat anyway.
        • Chris Parsons
          • Aug 2015
          • 195
          • Orlando
          • 1997 Sport Nautique 1995 Super Sport Nautique
          Pics!!
          • brit_hunsicker
            • Oct 2014
            • 483
            • Overbrook, KS
            • 2001 Super Air Nautique
            Tempting to try. Mines been knocked out for 5 plus years. Half the display is barely readable. Would love to try though just to see if I can get accurate hour reading.
            • functionoverfashion
              • Jun 2017
              • 514
              • New Hampshire
              • 2003 SANTE
              Glad that worked! This sounds a lot like leaving a dunked cell phone in a container of rice... I wonder if that would work? You might end up with rice stuck inside the gauge though.
              • boltonn
                • Jan 2010
                • 41
                • Alabama
                • Former boat 2001 Air Nautique Former Boat 1992 Nautique Excel Open Bow Current Boat 1997 Nautique Super Sport Masters Edition
                I did the same with a gauge on a 92 excel i just sold. I took the gauge apart just as you described. And glued it back together with gorilla glue. I didnt think about the silica packs thats genius. Amazingly it began working again. Not sure if it was a long term fix as i no longer have the boat.
                Sent from my SM-G955U using PLT Nautique mobile app
                • jkallen21
                  • Jan 2013
                  • 401
                  • United States
                  Here is the video of what I did. Sorry this took me so long. At the end I talk about soldering the inside (not what I would recommend). To be clear, what I was saying is that you would need to simply re-heat the solder joints and possibly add a tiny bit. The joints are obvious to see, but which one(s) isn't working won't be so obvious so you'd have to do them all. Again - don't go this route unless the silica packets don't work and if you're willing to have the cut chrome ring visible on your dash (forever). I also let mine sit inside the house for at least 2 weeks to completely dry out.
                  • alex_52
                    • Aug 2019
                    • 10
                    • Russia Nigniy Novgorod
                    • nautique 216 03
                    Good afternoon, I'm putting selikagel in the boat for the winter for the cat's toilet . I put them in bags (made of men's socks) and put them in different places in the hold of the boat .
                    • jkallen21
                      • Jan 2013
                      • 401
                      • United States
                      I use 3 containers of damp-rid and each one is half full of water in the spring.
                      • wakeballer
                        • Sep 2020
                        • 4
                        • Waterdown, Ontario
                        • 1995 Super Sport Nautique
                        I upgraded my Perfect Pass Gauge to a Smart Phone interface by NICKiNAV.
                        Turn your older wake/ski boat into a smart boat lol.
                        It's plug and play with the older Perfect Pass connectors, Just replace your Perfect Pass Module with the NickiNav module to upgrade your Perfect Pass to GPS for ~$400.
                        Best part is that it integrates your set-speed and volume controls to automatically raise and lower your media volume when you take off and slow back down!
                        www.nickinav.com
                        • MN Ryan
                          • Aug 2020
                          • 1398
                          • Maple Grove, MN
                          • 2007 SV-211 TE
                          That looks interesting, and the volume control would be sweet. Did you just leave the dead PP gauge in the cluster or put something else there?
                          Sent from my SM-G970U using Tapatalk
                          • bturner
                            • Jun 2019
                            • 1784
                            • MI
                            • 2016 200 Sport Nautique
                            I bought the App for something like $5. Should be interesting to see if it works. I really was just looking for the speed with 1/10s so I can "tune in" my speedo but I'll take the sound deal as a bonus, if it works.....
                            • MN Ryan
                              • Aug 2020
                              • 1398
                              • Maple Grove, MN
                              • 2007 SV-211 TE
                              Oh, I didn't realize you could just buy the app and use it without the control module. Please update if the volume control works. It's frigging snowing here right now, so it'll be a while before I can try it.
