New to me 2001 SAN Ballast Install
  • scarlso2
    • Nov 2015
    • 13
    • Houston, TX
    • 2001 SAN 210
    Got this 2001 SAN a couple months ago, had the upholstery replaced shorty after. Ever since I've been studying everyone's ballast installs on here. I'm just about finished with mine. I got everything from Wakemakers, they were super helpful and answered any questions I had. I removed all the stock pumps and tanks first. I used the factory thru hull and drilled 2 more. I mounted 3 Johnson pumps on an aluminum plate in between the back bench and the ski pylon. I've got 2 750's in the back, a bag in the ski locker, and a bow bag. To fill I used 1" hose. 1 pump each for the 750's in the back, and I Y'd off the third pump to the locker and bow bags. For vents I used 3/4" hose. I replaced all the stock plastic thru hulls with stainless. I crossed the vent lines in the back and used check valves and plumbed it to the stock ballast above waterline thru hulls.For venting the bow and locker bags I installed check valves then y'd it back together and sent it to the stock thru hull on the starboard side. I'm not sure what this thru hull was used for originally, but it had something to do with the stock ballast system. Wiring's not something I'm familiar with, but Wakemakers made it easy. Everything I needed came from them and I just plugged everything in. I mounted the switches next to the old ballast guages. There was just enough room and it looked almost factory made. More pictures to follow. Click image for larger version
  • scarlso2
    • Nov 2015
    • 13
    • Houston, TX
    • 2001 SAN 210
ID:	479040 Click image for larger version
    • scarlso2
      • Nov 2015
      • 13
      • Houston, TX
      • 2001 SAN 210
      Ballast Switches Click image for larger version
ID:	479044 Click image for larger version
ID:	479046 Click image for larger version
ID:	479045 Click image for larger version
ID:	479043 Click image for larger version
      • scarlso2
        • Nov 2015
        • 13
        • Houston, TX
        • 2001 SAN 210
        Pumps Click image for larger version
ID:	479048 Click image for larger version
ID:	479049 Click image for larger version
ID:	479050 Click image for larger version
        • scarlso2
          • Nov 2015
          • 13
          • Houston, TX
          • 2001 SAN 210
          Bags Click image for larger version
          • scarlso2
            • Nov 2015
            • 13
            • Houston, TX
            • 2001 SAN 210
            Thru Hulls Click image for larger version
            • DLafont
              • May 2009
              • 340
              • Gatineau Qc
              Nice! Show us the wake you get once you're on the water!! I like the wheels on the trailer too!
              Previous: 1990 Ski Nautique
              • swatguy
                • 1638
                • Midwest/ Northern IL
                • 2008 SANTE 210
                Man I love these threads. Nicely done. Love the gelcoat scheme on that boat
                • scarlso2
                  • Nov 2015
                  • 13
                  • Houston, TX
                  • 2001 SAN 210
                  Got it out today. Wake was incredible. Sorry the pics aren't the best. I'll work on getting more that do it justice. I'm guessing we had 3300 lbs including people. 1500 in the engine compartments, 700 in the ski locker, 300 from the integrated bow, 300 sac on the bow seats and 500 from passengers in the wrap-around seats Click image for larger version
ID:	482449 Click image for larger version
