97 ski nautique seadek project
  • swooddc
    • Oct 2006
    • 147
    • Gardendale, AL
    so i decided it was time to do the interior of our 97 closed bow. Here's what I decided on.
    1. Full set of Vinyl through Tim at inboard solutions that I am installing...
    2. Full floor seadek, in grey faux teak.
    Got the templates done and am waiting on the "dry fit" mylar mock ups to test fit the pieces.
    I'm about half way through the Skins, should be done this week. eliminating the carpet required some type of finishing on the naked fiberglass, I elected to Gel Coat the entire floor. I am about halfway done with that portion as well. With the carpet removed I was unhappy with the size of gap around the stern center floor piece and the cooler lids so I have custom cut new center piece and cooler lids out of 3/4" Coosa composites bluewater 26. Those are done, gel coated and look great. Over all I am very pleased with the project and looking forward to my new 1600 hr boat. BTW, should have started this in January instead of March. When I figure out how to upload pics I will post a bunch...
  • s_kelley2000
    • 1595
    • Fort Meadow Recevoir
    • Mass
    Wow sounds like a really cool project, I can't wait to see some pics. What are you going to do for the hull sides? Did you leave that carpet in place or are you gel coating that as well?
    To add pics, click the Go Advanced Button when you are writing a post, then click Manage Attachments and then it's pretty self explanatory from there.
    Shawn
    2012 Blue Metal Flake SAN 230
    • swooddc
      • Oct 2006
      • 147
      • Gardendale, AL
      Good question, my best idea right now is go back with carpet. I am also considering some of the bulk seadek product but not sure how to handle the vibration dampening panels. carpet seems the easiest option for sure. I'm going to try and gel coat the observer base and clamshell base. trying to eliminate all the carpet I can.
ID:	366038Click image for larger version
ID:	366037Click image for larger version
      • swooddc
        • Oct 2006
        • 147
        • Gardendale, AL
        my seadek drawing so far.
        seadek.pdf
        • swooddc
          • Oct 2006
          • 147
          • Gardendale, AL
          gel coat on driver area
          • swooddc
            • Oct 2006
            • 147
            • Gardendale, AL
            seadek dry fit templates
            Got my "dry fit" templates in, looking pretty good. gives me an idea what the finished product will look like. very different.
ID:	366078Click image for larger version
            • s_kelley2000
              • 1595
              • Mass
              Cool stuff! I can't wait to see the finished product but it looks like you are proving that you can add Sea Deck to the boats without snap in carpet as long as you are willing to do some additional prep work.
              Shawn
              • swooddc
                • Oct 2006
                • 147
                • Gardendale, AL
                it really cleans up pretty good, Seadek says it will stick to naked fiberglass so I initially was just going to gelcoat the gaps and around the edge. It went on easily enough so decided to gel the whole floor. Getting the adhesive up was the tedious part, I have enjoyed doing the gelcoat.
                • High altitude
                  • Oct 2011
                  • 206
                  • Larkspur, CO
                  • 2014 SN 200 OB
                  How did this ever turn out? Any pics of the finished product? TIA. -Marc
                  • swooddc
                    • Oct 2006
                    • 147
                    • Gardendale, AL
                    I'm still waiting on production of the seadek. got the vinyl done and am pleased overall, quality of the skins was amazing. My install skills have improved, a bit too late for one or two pieces...
                    A couple of observations on the no carpet nautique. The carpet does a lot that isn't readily apparent in the fit of the different moving parts. Also it seems to provided a good bit of sound deadening. I am hoping that the seadek, when installed helps but right now there is quite a resonate drone sitting in the stern seat that wasn't there with the carpet. I have some ideas to try, but any suggestions are appreciated. I will post some pics tomorrow of the finished gel coat on the seat bases and motor box.
                    • swooddc
                      • Oct 2006
                      • 147
                      • Gardendale, AL
                      seat bases sans carpet
ID:	366492Click image for larger version
                      Here are some pics of the finished vinyl and seat bases. I really like the no carpet look.
                      I got a little problem with the floor cracking behind the pylon. my pylon was bent and had cracked the floor immediately behind it. I repaired with fiberglass mat and resin but my repair cracked also. I slid the box back about 1/2" because the pylon was compressing the vinyl on the box. as you can see in the pics I had to extend the floor a bit to fill the opening.
                      Any input on the cracked floor would be appreciated, I also don't get my feelings hurt so flame away if necessary.
                      • swooddc
                        • Oct 2006
                        • 147
                        • Gardendale, AL
                        Got notice from seadek today, they are making my deck Monday, and giving me a discount for the delay. I have been pleased so far with the process, their cad dept. has been a little slow due to the season I suppose. But I will be good to go for my week at smith lake on the 4th, which was my goal.... Pics next week when I get it installed.
                        • swooddc
                          • Oct 2006
                          • 147
                          • Gardendale, AL
                          got my seadek in and laid it out in the boat. I feel a little like the crazy guy in the corner, a bunch of looks and no comments.... anyway for who's interested this is where I'm at.
                          P.S. sorry for the upside down pics. didn't get them edited right.
Name:	whole floor.jpg
ID:	366536Click image for larger version
ID:	366537Click image for larger version
ID:	366535Click image for larger version
                          • s_kelley2000
                            • 1595
                            • Mass
                            Nice job, that looks awesome! I look forward to seeing a shot with all of the interior back in the boat. Any ideas how many total hours you have into the project?
                            Shawn
                            • swooddc
                              • Oct 2006
                              • 147
                              • Gardendale, AL
                              hard to say on time, just the floor probably 16 hours. Gel coating the motor box base and seat bases probably 8 hours or so. The problem figuring time is waiting for resin and gel to cure before moving to the next step. so I've done it an hour or so at a time, the first batch of gel I put down took 4-5 days to completely cure due to the cool weather. Had to put a heater under the cover in my garage.
