Depth Finder began locking-on to 3.8 ft instead of correct depth. Sometimes it would read accurately, sometimes 3.8 ft. Became increasingly more common to be 3.8 ft all of the time. Bought a new Airmar Transducer from White Lake, removed old transducer from hull, sealed it in with Boat Life Caulk and ran wires under floor to dash. Wire was connected to Gateway Box at P13 with a Deutsch Connector. Ordered new Deutsch Connector parts from Ladd Industries (laddinc.com): (2) #0462-201-16141 (1) #DT06-2S, (1) #W2SA. Installed new Deutsch Connector onto wire from new Transducer and plugged it into the Gateway Box. Problem solved.
I need to do something about the depth sounder in my 04 sante 210. Thing is always beeping TOO DEEP or TOO SHALLOWOriginally posted by scottb7 View PostI fixed mine this week in 2008 sante 210. Replaced depth sounder. Ran wire to help, spliced into existing plug. Good to go.
and its a bear to turn off altogether. the button sequence in the manual lied to me
Are you still about mate?
I'm having massive issues with my depth sounder and can't figure it out. I don't have a manual at all which doesn't help!
