disabling perfect pass?
  • fattymrm999
    • Mar 2007
    • 19
    • Denver, CO
    • 2006 SANTE 210
    I'm trying to figure out a stalling problem that my 06 SANTE is having. I've been going down the list of possible causes and would like to single out the Perfect Pass to see if it could be the cause. My question is, How can I unhook/disable the perfect pass? Is there a fuse I can pull? Or do I have to unhook the wiring on the back of the Faria gauge? Your advice is appreciated.
    Thanks,
    Matt
  • NCH2oSki
    • 1159
    • Maryville, TN
    • 2005 ski nautique 206 SE
    RE: disabling perfect pass?
    Why not just turn it off?
    Prior Boats:
    1999 Ski Nautique GT-40
    www.skiersofknoxville.org
    • fattymrm999
      • Mar 2007
      • 19
      • Denver, CO
      • 2006 SANTE 210
      my problem occurs even when it is off. I have a suspicion that even though it is turned off a problem with the PP computer may affect the throttle on the boat. When perfect pass is switched off and I hit a bump, it beeps and I lose all throttle control and the boat returns to idle. I checked the wires on the back and they seem to be tight.
      • ag4ever
        • Feb 2004
        • 1180
        Unplug the wiring to the PP box. I assume it is under the dash and easily accessible.
        • skiinxs
          • 374
          • St. Louis
          • 2019 Ski Nautique 6.2 arriving soon
          In 06 there is no perfectpass box, just the in-dash display and the program chip that lives in the Faria gateway box. With the throttle by wire systems, there is not a lot of hardware involved in Perfectpass. In dash display, chip in Faria box, paddle wheel, (and slalom/jump timer(s) and rope switch if used)
          Dave
          16 other Ski Nautiques
          3 MasterCrafts
          18 Ski Supreme's
          1 SlickCraft Squirt Boat
          • fattymrm999
            • Mar 2007
            • 19
            • Denver, CO
            • 2006 SANTE 210
            can the chip be pulled from the faria box?
            • boatech
              • Aug 2006
              • 247
              pcm sent out a tsb for this problem call them they will help you. or give me a couple of days and ill track it down for you.
              • fattymrm999
                • Mar 2007
                • 19
                • Denver, CO
                • 2006 SANTE 210
                that would be very helpful, let me know what you find.
                • itssh0rty
                  • Aug 2009
                  • 2
                  I am having similar problems on my 2004 210 Air Nautique. When Perfect Pass is on, the boat will be running fine and then all of a sudden stall. PP goes blank, all of the dash lights go off, but the boat never goes dead. I bring the boat to neutral and then resume speed just fine. It does this sporadically. At other times, PP will randomly beep and reset itself, but the boat doesn't stall. These problems occur regardless if PP is on or off. Any suggestions would be great!
                  • TaylorAirNautique226
                    • May 2020
                    • 1
                    • Seattle
                    • 2007 Air Nautique 226 TE
                    I’m currently having this issue with my 07 226. Any insight so I don’t have to reach out to PCM, would be greatly appreciated. My boat stops when I go full throttle, but I can gradually get up to speed. Seemed to have started after calibrating my speeds on both the PP and Speedo.
                    thanks
