I have same situation in my 02 SS. Hit wakes and died, twice. Today I checked connections between batteries and to engine, lynyard, toggle switch and connections at braker box. Everything looks solid. I sanded and cleaned all connections. Hopefully it fixes.
If it happens again after doing what you've done, I'd swap out the toggle switch and see what happens.Originally posted by a.klos View PostI have same situation in my 02 SS. Hit wakes and died, twice. Today I checked connections between batteries and to engine, lynyard, toggle switch and connections at braker box. Everything looks solid. I sanded and cleaned all connections. Hopefully it fixes.2009 Super Air Nautique 210 TE
1989 Sport Nautique
Check oil level. Mine was doing the same thing. Come to find out, oil was way low. I think when engine loses oil pressure for a fraction of a second, the boat goes into limp mode. Shutting off and restarting resets everything back to normal.Originally posted by fattymrm999 View PostI have an 06 SANTE 210 which runs perfect in every way except when I hit a large wave the engine stalls. This happened about 5 times the other day. The engine does not shut off completely. It still is running however and all the guages appear normal, but it has no throttle control. The only way to regain trottle control is to shut off the engine and restart it. It seems like the throttle linkage comes loose, but I believe these things are drive by wire so there is no physical linkage to come loose. Has this happened to anybody? Any recommendations?
Thanks.
Sent from my SM-G930V using Tapatalk
