My 2007 Ski Nautique isn't drawing in cooling water.
I winterized the boat and when returned to operation, noticed the analog temperature gauge wasn't functioning. Based on advice in another thread, I replaced the thermostat.
Can replacing the thermostat & gasket cause an air leak that is creating my issue? T-stat is downstream of the impeller. I did re-snug thermostat bolts, the was gasket installed dry. Should I apply gasket sealer?
History:
Removed strainer bowl and put new teflon tape on the plastic fittings then reinstalled. No help.
Primed the strainer bowl with water and boat ran fine. Able to ski 1 set. Temp gauge worked properly.
Next time out, it will not draw water into strainer. Tried revving engine, no luck. Have tightened all hose clamps with nut driver.
Replaced impeller twice due to running while dry. They both had a minor rash but not missing chunks.
Eliminated strainer by running an intake hose from a bucket feeding hose into the trans cooler. https://youtu.be/AE37Gt70DF8?si=qvGIQp6tZWcYalQg
Engine drew water down about an inch and quit pulling water.
That's where I am, what next?
History:
