Excalibur 330 Impeller not drawing water
  • JayG80
    • Dec 2006
    • 255
    • Santa Fe, TX
    • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
    My 2007 Ski Nautique isn't drawing in cooling water.
    I winterized the boat and when returned to operation, noticed the analog temperature gauge wasn't functioning. Based on advice in another thread, I replaced the thermostat.
    Can replacing the thermostat & gasket cause an air leak that is creating my issue? T-stat is downstream of the impeller. I did re-snug thermostat bolts, the was gasket installed dry. Should I apply gasket sealer?
    History:
    Removed strainer bowl and put new teflon tape on the plastic fittings then reinstalled. No help.
    Primed the strainer bowl with water and boat ran fine. Able to ski 1 set. Temp gauge worked properly.
    Next time out, it will not draw water into strainer. Tried revving engine, no luck. Have tightened all hose clamps with nut driver.
    Replaced impeller twice due to running while dry. They both had a minor rash but not missing chunks.
    Eliminated strainer by running an intake hose from a bucket feeding hose into the trans cooler. https://youtu.be/AE37Gt70DF8?si=qvGIQp6tZWcYalQg
    Engine drew water down about an inch and quit pulling water.
    That's where I am, what next?
  • teamseal
    • Dec 2006
    • 416
    • Panama city, Florida.
    • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
    check the on hub on the impeller and see if it is spinning in the rubber.
    where did you get your impeller?
    • JayG80
      • Dec 2006
      • 255
      • Santa Fe, TX
      Thanks Jody, the impeller isn't spinning on its hub. I'm on the 2nd impeller in a week and it is a PCM RP061022 from nautiqueparts.com. Changed o-ring each time.
      Can thermostat gasket without sealer cause an air leak?
      • SilentSeven
        • Feb 2014
        • 2217
        • Bellevue WA
        • 2004 Nautique 206
        I see you said you checked the hose clamps but this really sounds like a classic air leak on the water draw side of raw water pump.
        I'd recheck all the hose clamps for tightness at each water feed line. Inspect each line from the through hull pickup to the raw water pump. If one is loose (or there is a hole in the water line), the pump will not lift water.
        Other items to look at:
        - Your thru-hull shut off valve is fully open right?
        - Have all the winterization plugs been re-installed and are snug? Specifically check with transcooler drain plug.
        - Does the water feed line have any tee's for things like showers or water temp gauges. Look at them closely for leaks.
        - I'd also make sure there's a good o-ring in the water filter. I've never had to use teflon tape.
        Let us know what you find out!
        Bellevue WA
        • core-rider
          • Feb 2004
          • 1375
          • Huntsville, AL
          • 2003 Black SANTE
          Anytime I remove the raw water pump/impeller I refill the entering hose (to the raw water pump) with water before starting. Those raw water pumps don't like pulling water dry and require priming. I also use some Dawn dishwashing soap to help lube the impeller on first start.
          Make sure you have the thru-hull open, strainer is full of water, hose from strainer to raw water pump is full of water and try again. If you see air bubbles in the strainer while running, then you have an air leak there likely at the O-ring gasket. The thermostat housing will show a leak if you're moving water by leaking out of the housing. Effectively that's the pressurized side of the system after the raw water pump and won't affect its operation.
          Jason
          All black 2003 SANTE
          -- Southern Fried --
          • JayG80
            • Dec 2006
            • 255
            • Santa Fe, TX
            Thanks Guys, Update - problem eliminated. Tranny plug was not tight enough and created air leak.
            I knew it was probably an air leak and had installed a new strainer and barb fittings because I suspected a bad bowl gasket or what might be a hairline bowl crack. That wasn't it.
            I filled the engine side hose from the strainer full with water until it backed up and also filled the strainer bowl. Ran the engine, only to empty the bowl but not refill it.
            Previously tightened clamps and plugs but decided to add new Teflon tape to the transmission cooler drain plug. That plug's brass threads show wear. I added new tape and threaded the plug in about 3/4 of the way. It was previously only threaded in about 1/2 way. Fired the engine and it is drawing water into the strainer and temp gauge ran up to normal.
            Will order a new brass plug soon. I am always cautious of over-tightening the brass plugs after I nearly stripped out the exhaust risers in my '99 Moomba.
            My 2007 Ski Nautique EX 330 came with a water strainer feeding 1.25" hoses into 1" strainer fittings. I replaced it with the same 1" strainer threads. Just had someone tell me it should be a 1.25" strainer threads for the 250 to 450 hp engines.
            • JayG80
              • Dec 2006
              • 255
              • Santa Fe, TX
              Update: air leak returned. Disconnected one strainer hose and stuck it in a bucket of water and ran the engine. It was pulling some water into the hose but the draw was weak. Riser temps went to 180.
              Pulled the new impeller out and got down low to inspect the raw water pump internals and found the internal back plate has uneven wear. Installed a new PCM raw water pump and ran at idle for 30 minutes and then simulated a couple slalom pulls. Riser temps were about 100 degrees.
              Can the pump internals be rebuilt or is it an $800 door stop?
