2007 SV211 Team - Prop Options
  • nhbouch
    • Aug 2016
    • 47
    • Bedford NH
    • 2007 SV211 Team
    Ok - so this is a long post - but dinged my prop last week (big drought here in NH and Lake Winnisquam is super low this year) - so I'll need to re-condition it but also considering other prop options are on the table. I'm running an Acme 537 and it is very good for skiing speeds and ok at surf / low end. My usage has changed from a small great ski lake to larger lake. My other prop is 1235 - great at surf but terrible at 34mph skiing speeds (prop wash is really bad). So, I spent some time in ChatGPT (cuz - why not) to run some analysis - you can read all about it below (if you're interested) - the analysis spit out the 1433 as the best option based on my usage.
    Any other SV211 owners running the Acme 1433? Any comments you could share?
    __________________________________________________ __________________________________________________ _________________________________________
    Summary of Findings & Prop Analysis
    Your Boat & Usage Profile
    • Boat: 2007 Nautique SV211 Team, 5.7L Excalibur 330 HP
    • Typical Load: 4-5 adults (125-200 lbs each), plus gear, cooler, boards, ballast as needed
    • Usage Breakdown:
      • 35% Surfing (10-11 mph)
      • 55% Cruising (18-22 mph)
      • 10% Skiing (34 mph)
    • Water Conditions: Lake Winnisquam, moderate to severe wind/boat chop, so surfing and cruising dominate over skiing
    Props Evaluated & Key Metrics
    Prop Size (D×P) Weighted Fuel (GPH) Wake/Surf Quality Prop Wash @ Surf Top Speed Loss Approx. Price (USD)WakeMakers / Acme
    1235 14.5" × 14.25" 8.98 (Best) Excellent Wake ❌ Too much spray ❌ 4-5 mph $720-$775
    1433 14.0" × 14.25" 9.93 Very Good Wake ⚪ Slight wash ❌ 2-3 mph $650-$725
    1579 14.25" × 14.0" 10.09 Very Good Wake ⚪ Slight wash ❌ 2-3 mph $600-$650
    1939 14.0" × 15.5" 10.36 Very Good Wake ⚪ Slight wash ❌ 2-3 mph $650-$725
    537 13.5" × 16.0" 11.68 Good Wake ✅ Clean ✅ None $570-$640
    645 13.25" × 16.0" 12.96 (Worst) Very Clean Wake ✅ Very clean ✅ None $570-$750
    Detailed Insights
    • Fuel Efficiency:
      • 1235 is the most fuel-efficient across your typical mixed usage.
      • 1433, 1579, and 1939 also offer good fuel efficiency but slightly higher consumption than 1235.
      • 537 and 645 have noticeably higher fuel consumption, especially during cruising and skiing speeds.
    • Wake & Surf Performance:
      • 537 and 645 produce the cleanest wakes with minimal prop wash — ideal if wake quality for surfing is your highest priority.
      • 1235 has the strongest low-end pull and best fuel economy but causes too much spray/wash at surf speeds, which could be a downside for your heavy surfing usage.
      • 1433, 1579, and 1939 balance wake quality and moderate prop wash, offering strong surf performance without the spray issues of 1235.
    • Top Speed Loss:
      • 537 and 645 have negligible top speed loss.
      • Others lose about 2-5 mph top speed due to pitch differences.
    • Price:
      • All props fall within a fairly close price range, with 537 generally being the most affordable and 1579/1939 at the higher end.
    Final Propeller Recommendations (Stack Ranked)
    1 1433 Best balanced: good fuel economy, very good wake, manageable prop wash, moderate price. Great all-around for your mix of surfing & cruising.
    2 1579 Similar to 1433, strong mid-range performance, very good fuel economy, and wake quality. Slightly more expensive but solid choice.
    3 1939 Slightly higher pitch, good all-around prop, wakes & fuel economy close to above. Great if you want a bit more thrust at higher speeds.
    4 537 Best for clean wakes & top speed, but fuel economy suffers. If wake quality for surfing tops your list, consider this despite higher fuel use.
    5 1235 Best fuel saver but poor prop wash for surf; not ideal for heavy surfing but great if you want to prioritize fuel and low-end power.
    6 645 Softest, cleanest wake but highest fuel consumption; best if wake quality is absolute priority and fuel is less a concern.
    Your Usage Context Considered
    Since you spend most time surfing and cruising in moderate to rough water (less skiing), wake quality and manageable prop wash are critical. Fuel efficiency is important but less so if wake quality and clean water behind the boat make your sessions better.
    My Top Pick: 1433
    • It offers the best balance for your typical use: fuel efficiency, wake quality, and prop wash.
    • You get good low-end pull for surf speeds and efficient cruise without too much spray.
    • Moderate price and very consistent performance.
    If you want a little more thrust or plan occasional higher-speed skiing, 1579 or 1939 are solid close seconds.
    If wake quality absolutely tops fuel economy, 537 or 645 deliver clean wakes with minimal prop wash but at a fuel cost.
  • wake_2001
    • Jan 2010
    • 3
    • FL
    • 2007 SV-211
    I tried to reply to your pm, but I guess I don't have enough posts.
    I went with the Power Tech equivalent of the Acme 1235. So far, I haven't noticed any prop burn and I've got 75-80 hours on it. It's been a solid choice for me. In order of time spent on each activity it's
    -foiling with little to no ballast (go surf assist helps)
    -surfing with factory + piggy back ballast
    -zup board for the kids
    -tubing
    -wakeboarding (wish this one was higher up)
    -skiing eventually as kids get older
    The Power Tech is heavier in comparison to the Acme 645 I took off. Not sure by how much or if it's enough to matter, but it's definitely beefier overall.
    *typed all of that before I read your post - I used ChatGPT to land on the 1235. I'd probably go with the 1433 in your case. If you mostly surf I wouldn't want to give up the torque. I haven't skied behind mine yet, so I haven't really noticed the prop wash.
    • MN Ryan
      • Aug 2020
      • 1394
      • Maple Grove, MN
      • 2007 SV-211 TE
      I chatted with you via PM, but for anyone else, I have had the 1939 on this same boat for several years and have been happy with it. It's a good combo for those that surf and ski.
      • FMSKI
        • Aug 2010
        • 244
        • Sproat Lake
        • 07 SV211 Ex330 Ski 'n Surf Sold (Ski 200, TSC1, 2001)
        I just ordered a 1433 have it coming today or tomorrow. I have a 645 on now we are bending the driveline at surf speeds, 3K in ballast with shapers on. The 645 really labors with every bag in the boat. So hoping to feel a bit better running heavy. I think to make difference we need to drop more than an inch in pitch. Bigger diameter helps with overall thrust, at the cost of efficiency, I imagine. So 1433 looks good on paper. I have spreadsheet of all the props that ppl have used on the SV211
        For reference:
        645 13.25 x 16p (my current)
        1939 14 x 15.5p
        1433 14x 14.25p
        • MN Ryan
          • Aug 2020
          • 1394
          • Maple Grove, MN
          • 2007 SV-211 TE
          I'll be interested to hear about the 1433. That's probably the direction I will lean when the time comes around.
          • FMSKI
            • Aug 2010
            • 244
            • Sproat Lake
            Prop arrived at noon. Got the boat to ramp/trailer myself, invovled running about a 1/2 mile each way between my place & ramp.
            Used a puller, 645 popped off easily,
            At the helm the 1433 drives about the same, except for the 4K rpm at 34mph ski speed. I saw more prop-wash rooster at slalom speed. Grabbed my neighbor to drive and went for a slalom ski. I've worked a lot to get the skiing to be pretty good.
            Unfortunately, the 1433 introduces a jet of a rooster that I didn't like very much. Still had a decent set though, so I could live with it.
            Heading home, had my modded Ronix Cortez surf with me so gated the boat up and surfed on the way back, no ballast, no gas, no pets & no cigarettes
            Coming out of the water was peaceful, and the wave actually shaped enough to almost ride it. I could get the rope loose but not sustained enough to toss.
            I am excited about the surf possibilities and going to ballast it up before it gets dark.
            Having a crappy surf wave is a real let-down, but a meh slalom set - it's only like 2 doz pulls or so and you're done.
            1433 prop with 3K Ballast, driver, FMSS Gate, swell gate, goofy side wave
            https://youtube.com/shorts/QR3AGhCfF...JfO7_K_vBpTqg-
            1433 Prop with No ballast, light fuel FMSS Gate, swell gate, goofy side wave
            https://youtube.com/shorts/gQxIXsKFf...eKxn1sXDk2rJrQ
            645 Prop with 3K Ballast, driver, FMSS Gate, swell gate, goofy side wave
            https://youtube.com/shorts/frt9tzuBz...wYNM_FaRK3Auk8
            • nhbouch
              • Aug 2016
              • 47
              • Bedford NH
              • 2007 SV211 Team
              Awesome feedback from all of you - I spoke with WakeMakers at length about this....they felt the 1433 would be closer to my experience with the 1235. So now I'm leaning towards the 1939 for how we use our boat.
              FMSKI - those YouTube videos are super cool, well done. Is it my perception or angle of the videos, but the 1433 looks to be taller/steeper wave vs. the 645?
              • FMSKI
                • Aug 2010
                • 244
                • Sproat Lake
                Oh for sure the wave is bigger with the 1433, just to be on the cusp of riding a wave with the boat in "slalom mode" (ie no ballast, low fuel, one driver only) is pretty crazy.
                Hope to surf the ballasted boat this aft!
                Prop rules by FM :
                1. For a better slalom ski wake/rooster, reduce diameter and increase pitch—minimizes the flow pipe size and increases prop lift. That's why the ACME 422 or 654 is a good prop for ski boats.
                2. For a big surf wake, simply go the other direction: increase diameter and decrease pitch—maximize flow pipe/push & decreases prop lift
                With this info, I have a paper weight of a prop the ACME 381 and I hated that thing. Sure it had good top end but man it didn't surf worth beans and skied nasty too. Because the pitch is massive, way too steep for surfing, and the diameter honking big for skiing.
                Therefore I am going to cut that sucker down to like 13" or less. It's funny that "rules" aren't well articulated by ACME or forum posts etc.
                and... figure out a way to change props at the dock :O. I have actually done that before, must have been crazy. Get a spare key and nut as our bottom is silty.
                • FMSKI
                  • Aug 2010
                  • 244
                  • Sproat Lake
                  I got my modded 381 13"x17.5 on there which is actually matches up to an ACME 497. The best for a slalom set, super flat at 32 off with the hydrogate deployed.
                  However I am getting a wobble on acceleration, which might be the prop because it wobbles on the countertop. The shop made it look good and am I sure it is balanced. But I do this flat surface test to see if the blades are in-line and it failed that.
                  • wake_2001
                    • Jan 2010
                    • 3
                    • FL
                    • 2007 SV-211
                    I had a wobble when pulling someone up with my old prop. It was a 645 that had been repaired by the dealer or previous owner. Everything appeared fine, but it failed the same test. No wobble with the new prop.
                    • jhoffy22
                      • May 2020
                      • 129
                      • Ohio
                      Do you still have the 1939 prop? I have the stock 645 prop on mine and have noticed that it's really struggling to maintain surfing speed when the boat is loaded up with people + ballast. If I recall, we have similar ballast setups.
                      We do a little slalom skiing as well, so that's a consideration for me in changing out props.
                      • MN Ryan
                        • Aug 2020
                        • 1394
                        • Maple Grove, MN
                        • 2007 SV-211 TE
                        Yep.
                        • jhoffy22
                          • May 2020
                          • 129
                          • Ohio
                          Yep.
                          Awesome. I assume that you're pretty happy with it in that case? I'm between the 1939, 1235, or 1443. Any downsides with your setup that you've noticed?
                          • MN Ryan
                            • Aug 2020
                            • 1394
                            • Maple Grove, MN
                            • 2007 SV-211 TE
                            I'm happy enough that I see no reason to change. It's kind of like the 211--not the best for any one thing, but a solid all-around choice.
                            • nhbouch
                              • Aug 2016
                              • 47
                              • Bedford NH
                              • 2007 SV211 Team
                              jhoffy22
                              I just put on the 1939 today - boat still in the driveway - spring weather hasn't been great, but now its 90 degrees . Plan to drop in for the summer over the next couple of days. I'll try to remember to post a couple of pics.
