2019 G25 NSS Surf Plate Cover
  • flooringguy103
    • Jul 2025
    • 2
    • Lake Cumberland
    • Versailles, Ky.
    • 2019 G25 Super Air
    After pulling onto the trailer this past weekend, I noticed that my cover plate was missing on the starboard side of my NSS system.
    The screws were intact with a small amount of the white from the cover plate still around the attachment screws.
    I have a new cover ordered, but I am wondering if anyone may have a suggestion as to why this may have happened.
    I do not want to install the new one, only to see it happen again.
  • Scooter G
    • Jan 2022
    • 1450
    • On a Lake in Idaho
    • 2022 G23 ZZ8
    Very unusual, I don't even know how that is possible. "We may never know".
    No other evident damage, downpipe, bottom hull, NCRS Plate?
    $218 plus shipping, not too horrible as things go, after the PN10 discount code.
    • BasaltRMK
      • Apr 2020
      • 311
      • Basalt, CO
      I've see cracks around some of the screws on two of my previous boats, so I'm not shocked. Had them repaired under warranty, definitely never lost a full cover plate though!
      - bob
      • GMLIII
        • May 2013
        • 2820
        flooringguy103 Actual I have send other posts on the lost of the plastic plate with the mounting screws intact. I agree it seems odd that this happen but it is more common than you think. Why I have no idea but hope someone would chime in on this issue. Not as common as failing ballast sensors but missing plastic plates do occur from time to time
        • hal2814
          • Jun 2016
          • 548
          • Ft Worth, TX
          It happens. Ride around your local marina and you're likely to spot at least one with a missing cover. Happened on my GS24 but they replaced it under warranty. I suspect the second any sort of crack or blemish starts letting water in, the cover is on borrowed time. That was 3 years ago and it hasn't happened to me since on my GS24 or the G23 I got to replace it, but I wouldn't be surprised if it happened again one day. It's a piece of plastic that's cupped against the flow of water. Physics has to win out occasionally.
          • flooringguy103
            • Jul 2025
            • 2
            • Lake Cumberland
            • Versailles, Ky.
            This is a picture showing the white plate that was left around the screws.
            Should these screws be tightened occasionally, or will this interfere with the plate deployment if they are too tight.
