GT-40 High Temp
  • behindpropellers
    • Apr 2008
    • 113
    • Chippewa Lake, Oh.
    GT-40 High Temp
    GT-40
    Runs 200 Degrees F.
    Checked sender - ~85 ohms with gauge reading ~200.
    New hoses, new bowl/gasket on strainer, new 160 thermostat. Made sure no debris in tstat housing.
    In water runs 200 degrees.
    Ran boat on hose to pressurize system to rule out air leaks. Still ran 200F.
    Circulation pump? I'm not sure of the failure mode and have never replaced one.
    Tim
  • Rednucleus
    • Jul 2022
    • 238
    • WA
    Are you going by dash gauge or have you verified by an alternate method? Any difference idle temps vs higher rpm's? What boat/year?
    • behindpropellers
      • Apr 2008
      • 113
      The dash gauge corresponds to the ohm reading at the sender. Here is the link to the faria ohm/temp: https://fariabeede.com/site_manuals/IS0085_E.pdf
      Boat is a 2000 SN 196. ~850 hours.
      • JayG80
        • Dec 2006
        • 230
        • Santa Fe, TX
        • 2007 Ski Nautique Sold 2002 Ski Nautique
        I imagine that you already changed out the impeller and made sure that it sealed properly. You might pull the hose off of the intake side of the transmission cooler and inspect for blockage.
        also, use a nut driver to tighten all hose clamps but use caution on the transmission cooler, I have seen the clamps over tightened and collapse the thin wall tubing
        • core-rider
          • Feb 2004
          • 1364
          • Huntsville, AL
          • 2003 Black SANTE
          Try back flushing the cooling system. High likelihood you have debris in the system blocking waterflow.
          Jason
          All black 2003 SANTE
          -- Southern Fried --
          • mpost
            • Jun 2007
            • 143
            • Monticello, MN.
            • 98 SN GT40
            Verify temp with an infrared at the sender or thermostat housing. IF the sender is bad it would rad a bad ohm reading. Good suggestions from JayG80; and JayG80;​ also.
            1998 SN GT40
            84 2001 Ski Nautique (sold)
            Monticello MN.
