I purchased a 2006 SV211 from a storage yard (who purchased it from a family moving across the country.). The boat has had a motor swap to a GM Vortec 5.7.
since I purchased the boat has intermittently bogged down to nearly an idle. It’s inconsistent; could run fine for 20 minutes or 2 minutes. When it bogs, all I have to do it idle for 30 seconds then she’s fine again.
so far I’ve replaced: cap, rotor, both fuel pumps, coil, fuel sending unit. The old fuel sending units black rubber magnet had half disintegrated into the tank. I took a magnet and got as much of it out as I could.
yesterday I tested fuel pressure. Both pre-bog and during bog I get about 70psi.
i “removed” perfect pass but snipping the grey wire and pulling the terminal plug to motor.
Thousands of dollars and tons of hours later I’m stumped.
anyone have any ideas? Thank you so much!
