2025 Tower Camera on Linc Display
  • morrow
    • Sep 2019
    • 107
    • Iowa
    • 2025 G21
    Here's a picture of mine from the weekend. That blob on the starboard side of the swim platform is actually a surfer. Not that you'd ever be able to tell. And yes, it looks the same if the surfer is directly behind the platform as well.
    • BasaltRMK
      • Apr 2020
      • 316
      • Basalt, CO
      Yeah, that definitely seems worse than mine. You might not be able to tell from the photos I took, but when my surfer is on the platform I can see them. And their face.
      - bob
      • cabofisher
        • Feb 2023
        • 1
        • Lake Conroe TX
        • Montgomery, TX
        • 100th Anniversary G25
        I have the same problem. I've had 2 G23's (prior gen) and cameras were decent. I owned a 2025 supra for 2 years and both cameras were 8/10. Just bought a new G25 and the camera is terrible. Completely useless. I never thought to look and see if there was a cover over the lens but will check tomorrow. If not improved I may try to buy a part for a prior gen G and see if I can change it out myself. I wonder if a 3rd party camera would be an even bigger improvement?
        This is replacement camera. May be worth playing around with...
        https://nautiqueparts.com/awareness-camera/
        • zuperair
          • Jul 2020
          • 3
          • MN
          • 1965 Sportsman 17 1997 Ski Nautique 2025 g23 ZZ8s
          I have a '25 G23 and the camera is very disappointing. I had a '14 G23 that I spec'd and ordered the awareness camera. It came with a handheld unit that had a tiny screen on it with an SD slot and some controls, and plugged into the driver's dash glovebox. When I got it, I was sure there was a screen protector or film covering the lens since the image was terrible and the videos it recorded to the SD were totally unusable. I totally regretted the option immediately when I found that there was nothing covering the lens or affecting the image. I'd heard the newer G's had great clarity and resolution, so I was psyched to have it in the new boat. Insert buzzer noise of your choice here, because it's absolutely terrible. Sure, you can see where the rider is in relation to your swim deck, but that's about all it's good for. I have old VHS tapes that have a clearer image. Love Love Love the '25 G, this camera isn't even close to the quality of the boat. 1 of 5 stars
          • morrow
            • Sep 2019
            • 107
            • Iowa
            • 2025 G21
            The new tower camera simply does not work. From everything I’ve been able to learn, this is affecting the entire 2025 G-series – G21, G23, G25. (Paragons are fine).
            The camera (or harness or related component) is welded into the tower, so the only fix is a full tower replacement. I was quoted over $20k for that.
            Nautique is unwilling to address it. They don’t appear to view it as a meaningful defect, even though the camera on my previous 2020 model worked properly and the 2026 models are again being marketed with a high-quality camera.
            I’ve been a Nautique owner for nearly 30 years and multiple boats. This is the first time I’ve felt the company is not standing behind a product issue of this size, and paying $20k+ to fix something that should have worked out of the factory isn’t a satisfactory solution.
            There is likely no resolution here unless we all get together and pursue a class action lawsuit. I just ended up turning my camera off since it isn’t functional.
            • Ckowals1
              • Aug 2019
              • 140
              • 2025 G23 Previous: 2019 G23, 2008 SAN 230 Team Edition
              #21
              Jumping on the bandwagon to agree that the 2025 G display of the camera image are terrible and that it would be nice to see this addressed in some way by Nautique..
              I came from a 2019 G23, whose camera I used often as it provided a crisp and clear picture.
              I find the 2025s camera worthless. Every time I’m in the boat I attempt to use the camera and immediately get reminded how I gave up on it the last time out.
              I find it very hard to spot a rider in the water within a surf ropes distance of the stern and I cannot see the hand signals a rider makes when surfing or in the water.
