Hello All, At the last trip of the season We were confronted with dead gauges on my 210 2006 SAN. The engine was still running but all the gauges were dead. Also the LCD's were gone. I was searching on the internet and found a company in New Zealand that did such a repair in the past.... I live in The Netherlands, Europe and New Zealand and for me New Zealdn is really at the other side of the world.... So I mailed and called a couple of times and I had the trust that they could fix it. AND I WAS CORRECT
I installed back the Faria gateway, the gauges and everything is back. ALL gauges are working and the LCD's are also working. Even the enginer hours were back. SO if you have a problem with your Faria gateway and you want to keep your boat original you can use my advice: Get Electronic Get Electronic – Get Electronic NZ
.I installed back the Faria gateway, the gauges and everything is back. ALL gauges are working and the LCD's are also working. Even the enginer hours were back. SO if you have a problem with your Faria gateway and you want to keep your boat original you can use my advice: Get Electronic Get Electronic – Get Electronic NZ
