Help!! No spark
  • GoCanada72
    • Aug 2021
    • 27
    • Canada
    • 85 Ski Supreme
    Help!! No spark
    Hey, I have an 85 Ski Supreme with 351 PCM. Not getting any spark. Limited tools on hand...should coil wire spark when held close to ground/metal while cranking?? I don’t get anything even when very close/touching metal.
    Is this normal? Boat is all original, points and distributor, not electronic ignition.
    Any help is appreciated.
  • Skidave
    • May 2005
    • 698
    • York, PA
    I bet your coil died or you have a wiring problem going to your coil. Should be able to get a suitable coil at an auto parts store. If you still have the ballast resistor, make sure it is not open (infinite resistance) or physically broken. This is all assuming you checked fuses for ignition and so on.
    • GoCanada72
      • Aug 2021
      • 27
      • Canada
      • 85 Ski Supreme
      I hair my hands on a multimeter and test light and I have voltage on + and - side, and the resistance of the coil is 9000 ohms I think. I picked up new coil at auto parts store that is to be used with ballast (I have ballast) . How do you check balance resistor? Coil I purchased is IC70 standard ignition coil.
      • gun-driver
        • Apr 2011
        • 132
        • Pittsburgh Pa
        if your getting 9 volts at the coil your ballast resistor is good.
        The last coil I got for my ‘85 was a Standard 1.5 ohm UF-2 and it should say on the box “external resistor required”
        • GoCanada72
          • Aug 2021
          • 27
          • Canada
          • 85 Ski Supreme
          Just measured 9-10 volts at +_- coil terminals with ignition on.
          • GoCanada72
            • Aug 2021
            • 27
            • Canada
            • 85 Ski Supreme
            Here is a pic showing voltage
            • GoCanada72
              • Aug 2021
              • 27
              • Canada
              • 85 Ski Supreme
              Here’s a pic showing resistance.
              • GoCanada72
                • Aug 2021
                • 27
                • Canada
                • 85 Ski Supreme
                Here is resistance of coil I bought. What I don’t get is, doesn’t the existing coil measure OK? Is it possible for the old coil to measure ok but still not work? I can try the new coil but i don’t want to mess anything up.
                • Scooter G
                  • Jan 2022
                  • 1434
                  • On a Lake in Idaho
                  • 2022 G23 ZZ8
                  Your points fire the spark from the coil. Could be wrong, but the old coil looks good. Maybe something under the cap, a bad condenser, usually under the cap, will shut you down. Points look good?
                  Check to see that your rotor is actually turning when you crank with the cap off.
                  • gun-driver
                    • Apr 2011
                    • 132
                    • Pittsburgh Pa
                    To test the primary resistance you need to disconnect the + and - wires the check across the to studs.
                    • GoCanada72
                      • Aug 2021
                      • 27
                      • Canada
                      • 85 Ski Supreme
                      Thanks I’ll disconnect the wires to coil and measure resistance across. Inside distributor looks clean. I put test light on coil and it flashes while cranking. I’m stumped . I’ll take pictures of inside of distributor. I tried to measure resistance of condenser and it seems to have resistance initially, then it drops, I saw somewhere that that was ok. With all the above, is there still chance it could be coil?
                      • GoCanada72
                        • Aug 2021
                        • 27
                        • Canada
                        • 85 Ski Supreme
                        I disconnected the wires and tested resistance of coil across studs, and it was 2.5 ohm, exact same as new coil.
                        • GoCanada72
                          • Aug 2021
                          • 27
                          • Canada
                          • 85 Ski Supreme
                          Inside distributor
                          • GoCanada72
                            • Aug 2021
                            • 27
                            • Canada
                            • 85 Ski Supreme
                            More of same
                            • GoCanada72
                              • Aug 2021
                              • 27
                              • Canada
                              • 85 Ski Supreme
                              Inside of cap
